Bespoke build
Old 07-18-2014, 05:38 PM
Britrover's Avatar
Default Bespoke build
Dear fellow members,
I am looking for a lead on someone who can do a bespoke headlamp build for me. I would like to have the projector xenons/hid fitted into the current headlight assembly. I understand to do this, I would need to get the projectors, xenon bulbs and ballasts, just looking for lead on someone who can do this bespoke build for me at a cost of course. We are based in FL, and I am open to shipping the headlight assembly for this to be completed.
I did a search and found a member in Brooklyn, NY who did this modification, but he has not been active on the forum your more than a couple of years. I know there are lots of talented folks who can do this and do this right, so just looking for a lead.
Thanks in advance for your help.
Old 07-19-2014, 06:18 AM
Britrover's Avatar
This is where I have landed after reading up on a lot of posts on the HID planet forum: Professional Retrofit Services and Vendors.
I have made contact with the top 3 vendors to see what the best options might be. I will post my update and the final end product with pictures as this progresses further.
Old 07-19-2014, 06:54 AM
Sean B's Avatar
Received 1,341 Likes on 1,057 Posts
it's easy enough to fit your own. You need the adaptors that push into the lamps, usually E36 bmw Xenon adaptors sourced from ebay. Once you have these, either cut and solder or spade connect the lamps to the car's lamp wiring. A wiring diagram assists.
The only thing that I found I required was a relay harness fitting with the system because on ignition with lights set to 'Auto' only one lamp fired (furthest from battery connection) the relay trigger gives both ballasts the same V so it cured my issue.
A major improvement imo.
Old 07-19-2014, 07:46 AM
DJ-Roy's Avatar
I got a H7 Philips set with E36 bmw Xenon adaptors ,much impromement.
mikiep
12-20-2019 07:37 PM
damienedwards
11-22-2015 10:51 AM
jospolice
10-02-2015 07:16 PM
Johncy2000
10-02-2015 01:05 AM
42Ajd
09-26-2015 07:04 PM
Quick Reply: Bespoke build
