XJR 1999 air conditioner
Old 03-08-2010, 11:59 AM
tanngo's Avatar
Default XJR 1999 air conditioner
hi guys...
I have a question about my car.
When I turn off the A/C and the car is running, the fans are still working.
(If I dont use the A/C the funs only work when the temperature goes up.)
(My car doesn´t have temperature problem)
Is this normal or my car has some problem?
Old 03-08-2010, 01:42 PM
QuadManiac's Avatar
Are you turning of just the AC by pressing the AC pushbutton, or turning off the temperature control system by depressing the fan button? If just turning off the AC button, this is normal.
Old 03-08-2010, 02:00 PM
tanngo's Avatar
I turn it off pressing the A/C button.Whats the difference?
Old 03-08-2010, 02:03 PM
QuadManiac's Avatar
That just turns off the AC compressor but not the rest of the system, like heater and fans. As long as cabin temperature is lower than set temperature, the system will still attempt to heat the cabin to reach set temperature. Depressing the fan button turns the entire system on and off.
Old 03-08-2010, 02:06 PM
tanngo's Avatar
OK, but the fans that I mean are the radiator fans.
Old 03-08-2010, 02:10 PM
QuadManiac's Avatar
Ah! Not understood from first post.
I suspect (but don't know for certain) that the cooling fans will remain on for some time after the AC compressor is turned off in order to continue cooling the pressure heated freon in the condensor.
One with better knowledge may be able to answer for sure.
Old 03-08-2010, 02:16 PM
tanngo's Avatar
SORRY!! I mean the radiator fans.
When I turn the A/C off, they still working.
They only turn off if I turn off the car or when the cooling system is in low temperature.
Old 03-08-2010, 04:03 PM
QuadManiac's Avatar
Understood, and I suspect that they stay on to continue cooling the heated freon in the condenser coil, which is directly in front of the radiator.
Old 03-08-2010, 11:07 PM
tanngo's Avatar
late very much in extinguishing fan . only when car this very cold
XJR 99, ONLY 10,000 miles, SUPER NEW
Old 03-10-2010, 10:33 AM
tanngo's Avatar
any suggestions ....
Donzi
10-18-2018 12:26 AM
Richxk8
09-16-2015 10:57 AM
Armor6
09-14-2015 07:56 PM
Armor6
09-10-2015 12:08 PM
jimmiejag
09-09-2015 02:56 PM
Quick Reply: XJR 1999 air conditioner
