Just cleaned wheel speed sensors
Old 08-30-2010, 02:26 PM
Parisdakarbmw's Avatar
Default Just cleaned wheel speed sensors
I pulled each sensor on my XJ8, and cleaned them up. They were all filthy!
My question now is, how far do I drive it before the failure lights should reset if that's the problem?
Old 08-30-2010, 04:15 PM
MidlifeXJR's Avatar
I have cleaned my two front sensors, and it did not seem to solve this problem. I'm afraid that the problem is actually the bad / broken solder joint on the ABS module control board.
You can search the forums to find some information on this topic. There is one with some good pictures. This may be in the XK8 / XKR forum.
I have not yet taken the module apart and looked at it, but I'm pretty sure that I am looking at this as the true source of the problem.
Old 08-30-2010, 09:14 PM
I found the thread. Thanks Midlife!
I'm looking to re-solder the module connections.
It doesn't look too hard, and could save some $$
Old 09-02-2010, 02:24 PM
jaginblack's Avatar
Hope you'll post back if that fixes it. I am about to clean and inspect mine and may need to go that route, too. Good luck -
Old 09-02-2010, 06:29 PM
dneider's Avatar
Could be wrong but I believe if you have a code scanner that can read JAG specific codes (aka the dealer or autoenginuity) it should tell you if there has been a pump failure or wheel speed sensor.
Forcedair1
05-14-2023 03:28 PM
PMKimpton
08-03-2019 08:22 PM
KarimPA
09-03-2015 07:32 PM
OkieTim
09-02-2015 12:48 PM
innzane
09-02-2015 10:08 AM
Quick Reply: Just cleaned wheel speed sensors
