XJ8 Remote Programming
Old 02-04-2014, 02:17 PM
Zorasmiles's Avatar
Looks like your door opening and locking pads aren't making good contact or worse yet, excess use along with a few other factors can indicate time for a new remote. I've taken apart a lot of other remotes tinkering but have yet to have the need to take apart the Jag remote. There are a couple of vendors from Ebay who sell the remotes at good prices (I have used two of them with great success). I'd look to purchase new remotes versus used remotes as you might run into the same problem/issues. On the bright side you were able to program and get it to work! Congrats on another task completed.
Old 02-07-2014, 06:39 PM
Jagged's Avatar
Thanks...thats just what I needed for my Vanden Plas...
Old 03-10-2014, 11:48 PM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
My 2001 XJ8L I did all the steps several times got the blinking J gate light but still nothing from the remote, new battery & cleaned contacts,terminals. Guess it's time for a replacement.
Old 03-11-2014, 03:28 PM
mcm97's Avatar
In a semi-related question, can you change the battery in these remotes?
Old 03-11-2014, 06:41 PM
The frustration level rises, today I cannot even get the blinking J-Gate light grrrrrr lol.
Old 03-19-2014, 06:55 PM
Update :
2001 XJ8L I get the flashing program light(no noticeable chirp though) on the shifter on each remote press that shows it's sending a signal. Yet when I remove the key & try the buttons none work,(checked contacts,battery all are good). Looks as if I need a new/replacement remote. I now know why the cat growls grrrrrrr lol.
So with the "learning/programming" light on the shifter console blinking with each press of the FOB remote that means it's sending a signal, so what else on the car can I check to remedy this.
Old 03-21-2014, 11:59 AM
Zorasmiles's Avatar
The remote unlock/lock control module can be checked but with the right testing equipment it will do you no good to find it lol I don't know where the module is located on our car as I didn't have to pursue that avenue when programming my remotes.
You might want to purchase another remote--see if it programs and operate as it should. If it does, you know your current remote is dead. Good luck.
donald ebanks
09-30-2015 07:08 PM
Swagguar
09-30-2015 01:34 PM
zdrapec
09-25-2015 05:49 AM
kevinl
09-24-2015 08:25 PM
Quick Reply: XJ8 Remote Programming
