Removing balljoints on my XJ8
Old 09-15-2017, 12:23 PM
bigcash's Avatar
Default Removing balljoints on my XJ8
Hey guys-
I'm replacing the ball joints since I have the hubs off and getting the new bearings pressed in.
The lowers are shot.
I rented the tools to get them off, but I'm having a little trouble getting the lower one to break lose.
I have the tool in place and have it torqued down pretty tight.
I used a breaker bar, but it wasn't up to the task. It broke. I have used my electric impact driver, but it's not doing it either.
The lowers do come out through the bottom, correct?
-Thanks-
-Cash
Old 09-15-2017, 12:28 PM
RJ237's Avatar
Received 2,781 Likes on 2,225 Posts
Check Johnken's writeup in the link below.
https://www.jaguarforums.com/forum/x...edback-188929/
Don B (10-02-2017)
Old 09-15-2017, 12:44 PM
hispeed42's Avatar
Hi Cash,
Yes, they come out through the bottom. I tried to replace mine a few years ago and it didn't work out to well. I have a 10,000 lb press (kind of a small bench top) and it couldn't budge them. I took them to a machine shop and they were able to R&R them but it took 20,000 lbs to get them out; I'm not sure how much to get the new ones in. After less than 10,000 miles, both were broken, not worn out, and I had to replace them, opting for the new arms with ball joint installed. Others may have had better luck replacing them.
There's a little more to the story if you want to hear it ...
Mark
2002 XJR-100
PS - I used to live in North Richland Hills
Old 09-15-2017, 02:21 PM
bigcash's Avatar
Ha. Any knowledge is good at this point.
-Cash
Old 09-15-2017, 06:36 PM
TreVoRTasmin's Avatar
While some have gotten luck with removing 'em with less than a 20 ton press, I have never been so lucky in fact every single one (except for the one that needed replaced about a year later as it failed) needed every ton of that 20 ton press and sounded like a shotgun when they finally broke loose.
Old 09-16-2017, 09:51 AM
Mark SF's Avatar
What I had to do is remove as much as possible of the joint, first cutting it off flush with a cut off wheel on a grinder, then drilling it out with the biggest drill I have, then making a couple of radial cuts outward, from the hole you just drilled, with a hacksaw or jigsaw, ideally stopping just before you hit the arm itself. The idea is to relieve the pressure on the press fit.
This worked on both sides, and I was able to remove the old joints and press the new ones out, in situ with the OTC 7249 tool.
Old 09-16-2017, 01:11 PM
bigcash's Avatar
I tried to take the front lower rearward wishbone off today. I rented the tool to ompress the spring, I could not get the tool onto the spring. Is there a specific sprinng compressor to use with these frot springs?
Old 09-16-2017, 02:25 PM
hispeed42's Avatar
It's a Jaguar, so of course there's a special tool !! It's a threaded rod that fits upwards through the middle of the spring and hooks into the notch at the top of the mount. There's a half-ball piece that slides up to the spring pan, then a crank handle that screws onto the rod to hold the pan while the bolts are removed. Here's a pic of it installed:
As you can see, it's about twice as long as needed for an X308, so I had to jack the front end up till the exhaust tips were almost to the floor. That was a lot of fun ...
The following 2 users liked this post by hispeed42:
Don B (10-02-2017), rocklandjag (09-17-2017)
Old 09-16-2017, 07:30 PM
bigcash's Avatar
Do you have the name of the tool?
Old 09-16-2017, 07:52 PM
Robman25's Avatar
I made one out of a piece of threaded rod, 19mm/ 3/4" with 2 nuts welded together for increased bearing aera and a couple of galvanised 2" square 3mm washers welded into a unequal L
The top of the rod needs to be cross drilled to accept a 6mm roll pin.
The roll pin seats into a depressed slot in the top housing.
Get some long bolts to suit the thead of the seat pan bolts to facilitate realigning the pan when refitting.
Don B (10-02-2017)
Old 09-16-2017, 08:01 PM
Mark SF's Avatar
Although if you do it the way I did it, the arm stays on the car.
Old 09-17-2017, 11:00 AM
bigcash's Avatar
I can't get the lower ball joints out of the wishbone so it' going to have to come off and go to the shop.
I don't see anything for sale like what hispeed42 shows.
Rodman25 - Do you have a photo of what you built?
Old 09-17-2017, 12:52 PM
hispeed42's Avatar
It's the Coil Spring Compressor, part number 204-111. Here's the Jag tool website: https://jaguar.service-solutions.com...3/1/Suspension
They're quite proud of this thing !! I would offer to let you use mine, but it's in a storage room 100 miles west of here.
MarkSF and Robman have some good ideas on work-arounds.
Don B (10-02-2017)
Old 09-17-2017, 01:50 PM
rotundapig's Avatar
My method was to replace each of the bolts holding in the spring perch with threaded rod, one at a time, to remove the spring. Once I had the control arms out, the key to getting the ball joints and bushing to press in and out was heat. A heat gun or small propane torch is enough to get the ball joints and bushing to press out relatively easily (at least that was my experience).
It it was a bit of a struggle to figure out the process, but after the first one, they all went smoothly.
Don B (10-02-2017)
Old 09-18-2017, 04:17 AM
Robman25's Avatar
I can post a few photos tomorrow.
Old 09-18-2017, 05:56 PM
Robman25's Avatar
Don B (10-02-2017)
Old 09-18-2017, 07:17 PM
hispeed42's Avatar
That will do the deed and at a much lower cost than buying the official tool.
Old 09-19-2017, 06:25 AM
bigcash's Avatar
Thanks hispeed42-
I'll give it a shot.
Old 09-20-2017, 07:30 AM
euphonium01's Avatar
I did the same as Robman25, piece of 19mm threaded bar, weld some pieces of bar to 2 19mm nuts as turn handles, drill a hole about 25mm down one end of the threaded bar and insert a roll pin, I used an 8mm pin. I also found it easier to use a few pieces of threaded bar (about 6 inch long or so) to replace the lower pan bolts, they acted as a guide when lowering the pan... worked a treat!
Old 10-02-2017, 07:11 AM
bigcash's Avatar
Default One wishbone down... one to go-
I chose the 6 - M10-1.5 threaded rod option.
It took a few days for Grainger to get stainless steel threaded rod in.
I cut it up into 6 12" lengths.
I finally found the various nuts I needed at Elliotts hardware in Plano-TX.
I decided to use coupling nuts because the length of the nuts would give me much more bite. I didn't want to chance a regular nut fa20iling under that kind of stress.
I used a length of pipe and cut it into 2" lengths.
I removed each bolt one at a time and replaced it with the threaded rod/2" pipe length/washer/coupler nut.
Then I just backed off each nut about 1/8" at a time and worked my way around the 5 rods until the spring was uncompressed.
Took about 20-30 minutes.
Ignore the large threaded rod in the middle. I was going to build the center of the spring compressor tool, but the other option looked easy enough. I just left that rod in there. It's just setting in there anyway.
It took longer to cut the rod and chase the threads than it did getting the spring/cradle off.
Cash-
1998 XJ8
Attached Thumbnails Removing balljoints on my XJ8-20170930_174136.jpg   Removing balljoints on my XJ8-20170930_181813.jpg   Removing balljoints on my XJ8-20170930_182258.jpg   Removing balljoints on my XJ8-20170930_184140.jpg   Removing balljoints on my XJ8-20170930_185243.jpg
The following 3 users liked this post by bigcash:
Don B (10-02-2017), kp98xj8 (10-06-2017), Samilcar (11-01-2017)
