Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X350 & X358 ) XJ6 / XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X350 & X358 ) XJ6 / XJ8 / XJR 2003 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 09-30-2009, 12:16 PM
chromecicada
Guest
Posts: n/a
Default '04 XJR drivers side heat problem
my 2004 XJ blows great heat from the passenger side vents, but only blows luke warm from the drivers side vents. Now that its getting cold outside, it needs to be addressed. Is this a common problem? Will i most likely need to remove the heater box to find the problem?
Old 09-30-2009, 01:45 PM
Brutal's Avatar
Photobucket
BILL BRUTON
Replace the heater control valve in the passenger front lower engine compartment and hope that it was only stuck closed and didnt short the ac control panel
__________________
Working for those that do not every day
Old 10-09-2009, 11:19 AM
chromecicada
Guest
Posts: n/a
Thanks for the quick response. This car doesn't have a heater control valve that i could find (i looked under the aux. water pump). What i ended up finding was a heater core that was half clogged with an orange gritty slime. the clogged portion extended into the drivers side of the heater box, while the free flowing portion was on the passenger side. Once i removed the glove box and the blower motor air box, it was fairly easy to replace.
This is a great forum! i hope this info can help someone else with a heat problem.
Old 10-09-2009, 12:06 PM
Brutal's Avatar
Photobucket
BILL BRUTON
Uh yes i work on them all day, it has a heater control valve(dual) that how it allows 2 different temp setting between the passenger and driver
__________________
Old 10-09-2009, 05:33 PM
chromecicada
Guest
Posts: n/a
Iím sorry for the misunderstanding, itís entirely my fault. I should have described the vehicle better. This is a 2004 Jaguar XJR supercharged 4.2. It has no dual heater control valve like, say an S-Type does (even with the same engine). The main difference is the type of heater core: the dual heater control valve system has three heater hoses going to the heater core. One for drivers side heat, one for passenger side heat, and a shared return line. It is essentially two heater cores in one. The non-dual heater control system has two heater hoses going to the heater core, one supply and one return. The dual zone temperature is controlled by blend door manipulation, not coolant flow.
Again, Iím sorry for the confusion. I know your time and knowledge are valuable and I appreciate you sharing a little of it with me.
Tags
2005, blend, control, door, drivers, dual, heat, heating, jaguar, location, motor, side, valve, vents, xj8, xjr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
