1998 xj8 tail lamps and tag lights not working
Old 09-18-2012, 08:49 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Check your fuses.
Old 09-19-2012, 11:22 AM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
I have a XJ8L 1998.
Just bear in mind that this is the forum for the X350 series of XJ saloons from 2003 to 2009. Your car is an X308 series and there is a forum, (and experts) for that. I think you'll get a better response there.
Old 06-06-2013, 06:11 PM
mpethel's Avatar
I know this is an old post, but to anyone who has had this same problem as I have. The problem is in the turn signal switch. There is a very small wire that can break from its solder as you are constantly using the turn signal. Take off the steering wheel ignition covers around the turn signal and you will very carefully have to solder this wire back on. I believe mine was yellow. my mileage also was not working along with everthing else. This fixed it all.
RColquhoun (06-08-2013)
MJ'S Jag
11-10-2022 08:14 AM
johnnie ryall
10-19-2015 09:44 PM
gene1
09-03-2015 08:04 PM
aquifer
08-29-2015 04:54 PM
gene1
08-27-2015 09:35 PM
Quick Reply: 1998 xj8 tail lamps and tag lights not working
