Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X350 & X358 ) XJ6 / XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X350 & X358 ) XJ6 / XJ8 / XJR 2003 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 02-15-2011, 07:45 PM
Default 2004 XJ8 Headlamp bulb replacement
Does anyone know how to remove the clip that holds the bulb assy in the housing. It's a metal clip and kinda hard to get to.
Old 02-16-2011, 01:28 PM
roviw's Avatar
I had to do my nearside ( UK car) bulb yesterday, it can be a struggle but once you have popped the rear cover off and pushed it down and to the side you can use a flat blade screwdriver to hook the lower part of the wire clip to the side from where it is hooked behind a small piece of metal, once free, it can be eased upwards but left attached at the top edge, almost like hinging it out of the way.
Then ease the electric plug from the rear of the bulb and carefully pull the bulb out using the two metal blade terminals sticking out.
Refit the new one ( keep fingers away from the glass) making sure the "notch" is at the top, drop the spring clip back down and ease it behind the metal notch to hold it in place, replace the electric plug and then manipulate the rear cover back into place and reclip the other metal clip to hold that cover tight.
Hope this helps and is not too long winded but a lot of people really struggle to change the bulbs as it is such a tight area to get your hands into. I also use a tiny torch, usually held in my mouth ! haha to help as it can be a bit dark down there.
Best of luck.
__________________
Previous Jaguar cars; 1983 4.2 Sov, 1988 3.6 Sov,1990 4.0 Sov,1994 3.2 Sov, 1998 4.0 LWB Sov, 2000 LWB Sov, 2003 XJ8 3.5 SE.
Current Cars; 2007 Transit Van , 2004 XJ super V8, 2011 XJL 3.0 Luxury, 2002 Jeep Grand Cherokee Overland
Old 02-16-2011, 08:28 PM
Thanks, I'll give it a try in the AM.
Best of luck.
Old 02-22-2011, 10:05 AM
See my post dated Feb. 11 for some perils.
relinuca
The Following User Says Thank You to relinuca For This Useful Post:
Kyd (02-29-2012)
Old 02-22-2011, 10:55 AM
kthrash's Avatar
Make sure when you reinstall the new H7 bulb to insert it with the tab pointed up.. it looks like it should point down but it really points up..
__________________
Current:
2007 Jaguar XK Convertible (Slate)
2006 Jeep Commander Limited 4x4 Hemi (Black)
2013 Ford Explorer XLT (Sterling Gray) Ordered!
Past:
2004 Jaguar XJ8 (Pacific Blue)
2006 Jaguar XJR (Slate Mica)
2004 Jaguar XJ8 (Slate Mica)
2006 Jaguar XJ8 (Quartz Mica)
1995 Jaguar XJS (Artic White)
Old 02-29-2012, 10:06 PM
Kyd Kyd is offline
Jeffrey Lear
Default RE: How to R & R 2004 XJ8 Head Lamp Bulb
Quote:
Well Danimo... How did the R & R go? My passenger's bulb went out; so I bought a new one from Auto Zone for $16 (H7) and am ready to install... Sounds like a tricky & tight manouver. Wondering how your ordeal went?
Any caveots?
Kyd
NE Florida USA
2004 XJ8 Sea Frost Green
Tags
2004, 2006, bulbs, burner, change, headlamp, headlight, jaguar, removing, replace, replacement, replacing, xj, xj8, xjr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
