Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X350 & X358 ) XJ6 / XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X350 & X358 ) XJ6 / XJ8 / XJR 2003 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
2004 xj8 transmission line leak
LinkBack Thread Tools Search this Thread
Old 04-18-2012, 12:57 PM
Default 2004 xj8 transmission line leak
Dealer just said I need to replace 2 transmission lines that are leaking. no fluid found under were I park my car.
I park the same place always. My car is a spring and summer car with 68,000. I keep it extremely clean inside and out and under the hood. they want 2k for that and a lower bushing. The car has been out of winter storage for 3 weeks and has no signs of shifting probelms or leaks. they found the leak during my yearly service today. any thoughts fron you guys.
Old 04-18-2012, 01:16 PM
What I'm about to say relates to cars in general and not necessarily our XJs.
Tranny lines generally refers to the fluid cooler lines that run to the radiator. These are not high pressure lines and can generally be repaired with a pressure patch (piece of hose and a small clamp). This assumes the leak is a pin hole or chafe type fault.
Sometimes you get a leak where the connector unions no longer seal That usually does require new lines.
A dealer serv operation is usually above such rough and ready fixes but most indies would do it for pennies on the dealer dollar.
__________________
Tarheal
07 XK Coupe. Sold. Best looking runner up, 05 XJR most satisfactory car I ever owned, 72 XJ6, 76 XJ6C, 72 XJ12 - mildly disappointing, 84 XJS, 69 XKE Conv't - Best looking
Old 04-18-2012, 08:37 PM
oldmots's Avatar
That got my suspicion meter twitching...I have never heard of this car with leaking transmission lines and I can't imagine that replacing them could cost $2K. Get a second opinion to be sure. It is possible that lines could leak, and if they did, it could land in the undertray and not get on the pavement, but still $2000 sounds incredible to me.
__________________
05 XJ8 4.2
04 Audi A6 Quattro 3.0
06 XKR Coupe
04 Jeep Wrangler
09 Kawasaki Concours 1400
65 BMW R69S
67 Velocette Venom Thruxton
89 Honda GB500TT
Old 04-19-2012, 05:57 AM
If you saw the condition of my car and how clean I keep it well you would understand my suspicion. I keep an eye on my cars.
Generally with most leaks in and around the engine, the leak would blow back on the exhaust and you would smell something burning.
The other thing the dealer told me don't worry about driving it unless you see a puddle under the car? As soon as I told them I was not having the work done he asked if they lowered the price from $2100 to $1800 would I do the job, I said no.
Any tech's have comments?
Old 04-19-2012, 07:12 AM
oldmots's Avatar
Go fo rth esecond opinion. the only leaks I have heard of are pan gaskets and electronics sleeves at about 60K. these are common. If the sleeve is leaking, the fluid will run down onto the pan edge and look like something else.
__________________
05 XJ8 4.2
06 XKR Coupe
04 Jeep Wrangler
65 BMW R69S
89 Honda GB500TT
Old 04-19-2012, 08:59 AM
MTW MTW is offline
I got mine replaced under warranty they were leaking from the connectors not a bad leak. I was told that this was a typical failure - though never read about this failure here. 2000 is ridiculous!!!
Old 04-19-2012, 11:08 AM
Mine developed a leak in one of the cooler lines where the rubber hose meets the metal portion that loops up over the suspension. Slight weep really....
I had it replaced by an indi shop with a Jag hose for not more than 200-300 as I recall. It was last year so I don't remember the amount.
Get another quote...
Tom
__________________
Regards,
Tom
2004 XJ8 205K miles
2011 XF S/C 18K miles
Coming soon---->>
TCP Intake, K&N Filters, VelocityAP Tune, 1.5# Pulley, Sport Cats, X-pipe, Sport Mufflers, WOO-HOO
Old 04-19-2012, 01:19 PM
ANy half-decent workshop will take you into the workshop and show you what is needed. My local indie did this when I had to have rear lower wishbones and lower spring unit bushes. Gives you confidence they are not talking out their **se
__________________
Fleet manager of: -
XJ6 Sport 2003 (X350)
MG Midget 1977
VW New Beetle 2001 (wife's)
Fiat 500 1.2 Sport 2009 (daughter's)
and now....
MG TF 135 2010
Old 04-26-2012, 09:17 AM
mosesbotbol's Avatar
mosesbotbol
2K is robbery. For under 1K you should be able to fix the transmission lines and replace the filter/pan/fluid service. Might as well do the whole thing and get it done at an indy shop.
__________________
2011 Lotus Evora | 2015.5 Volvo S60 T5 AWD | 2005 Range Rover HSE (sold) | 2007 XK Coupe (sold) |2004 XJ8 Vanden Plas (sold)
Old 04-04-2013, 10:45 PM
Robert Page's Avatar
Old thread I know but had to mention, had my trans pan changed today as had leak bought the parts myself from Klaus at the CTSC and supplied them to my local Jag dealer who then did the work. My tech is a 30 yr vet and I trust him, he asked me to come and look at the Trans lines both are leaking at the crimp joint rubber to metal ( modern production technique ) parts are under $200 but the labour is the problem as I saw the routing and the stuff that has to be removed is crazy! So in the end the bill will be $1000 we have no Indy Jag mechs in the Raleigh area so options are slim. The leaks are not bad and my XJR is not my daily driver so I will let things develop and see if I can get another 1000 miles out of them. I have had this issue on Landrovers, Range Rovers and Jeeps before so nothing new just wish that car companies would use male to female screw fitting on Rubber to metal pipes like in the old days but that is more expensive to produce. The pipes are only as good as the crimping machine.
Old 04-05-2013, 01:34 AM
Old thread but well timed revival. Our XJ supposedly has leaking lines as well, per our Jag dealer. If it is the crimp, is there a possible fix of cutting off the factory crimp, adding a new one from a donor section and splicing the new piece to the old line with rubber hose? This would make future service easier and save a bunch of labor pulling out the entire run of line.
Just some thoughts.
Old 04-25-2013, 08:00 AM
Send a message via Yahoo to Clamdigger
Default trans line leak
I just had my XJ towed to the dealer for a major coolant leak that came on all of a sudden. Just started out on a 700 mile road trip when the "low coolant" message came on, and yes I checked all fluid levels and pressure in the tyres before setting out. I turned right around, kitty did get us home, and took the wife's Mustang.
My warranty runs out in July and I have a few minor issues so I thought sending it to dealer to get checked out completely would be best.
One thing they tell me is kitty has a transmission line leak and it's not covered by my warranty and at a cost to me of $1500.00. Oh yes the coolant leak was one of the two hoses under the intake manifold and not covered under warranty $650.00
I always look under the car for any tell tails and have never seen any coolant or more important now trans fluid, so I told them not to do the tranny lines. I hope I'm not making a mistake.
To be fair to the dealer they are doing about $4500.00 dollars worth of repairs that are being covered by warranty.
Any input on the tranny lines would be appreciated.
__________________
Barry NJ, USA
2007 XJ8 4.2L
2006 Mustang Conv V6
1999 GMC Serria 2500 6.0L- Hurricane Sandy took it to the graveyard
Old 04-26-2013, 08:34 AM
Same trans line issue with mine. I bought it from Jag and replaced it myself. Not easy by any stretch but doable. Tell me there's not a defect. 04.R with 50 k.
Old 04-26-2013, 07:01 PM
plums's Avatar
Quote:
Just some thoughts.
As has been described elsewhere, the outer crimp sleeve usually covers an inner ferrule. If the outer crimp sleeve and hose is cut away, the remaining hose can be pushed onto the ferrule and secured by a good old fashioned hose clamp.
The Following User Says Thank You to plums For This Useful Post:
Clamdigger (04-27-2013)
Old 04-27-2013, 11:25 PM
Mine is leaking too so I got new line just waiting to put it on.
__________________
2005 Jaguar XJR
Old 04-28-2013, 06:24 AM
Casper,
How much did you pay for the lines?
__________________
Barry NJ, USA
2007 XJ8 4.2L
Old 04-28-2013, 06:12 PM
I can't remember the exact number because I don't have the receipt with me but it's either 209 or 219 for the set from a dealer farther away from me. the dealer that is closer to me like maybe 2 miles away wanted 289 for it. So I drove 45 min to get it while going that way for a meal.
__________________
2005 Jaguar XJR
The Following User Says Thank You to Casper For This Useful Post:
Clamdigger (04-29-2013)
Old 04-29-2013, 03:38 PM
Hello Casper do you have the part number. Thanks
Old 04-29-2013, 10:22 PM
C2c40418
__________________
2005 Jaguar XJR
Old 04-30-2013, 05:07 PM
Thanks very much Casper!
Tags
2004, cars, cooler, gasket, jaguar, leak, leaky, line, lines, pan, pressure, tranmission, tranmssion, trans, transmission, xj8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
