Bank 2 Upstream 1 Lambda / O2 Sensor location
Old 11-24-2013, 06:39 AM
geekman's Avatar
Default Bank 2 Upstream 1 Lambda / O2 Sensor location
My engine management light recently illuminated on my 2003 X350 XJ6.
I got the codes read and it came up with P1647 - lambda / oxygen sensor failure, bank 2 upstream 1.
I've sourced a replacement sensor and I'm going to attempt installing it myself with the help of a mechanically minded friend.
So, can anyone tell me where the sensor is located?
Old 11-24-2013, 07:10 AM
GGG is online now
Received 16,792 Likes on 12,165 Posts
Bank 1 = RH
Bank 2 = LH
For identification purposes, LH and RH are as sitting in the driver' seat looking forwards.
Bank 2 Upstream 1 Lambda / O2 Sensor location-x350-sensors.jpg
The sensors can be very tight!
Old 11-24-2013, 08:49 AM
geekman's Avatar
Thanks - so it's the sensor you've pointed the red arrow at? Stupid question I know but I want to be sure before we start attacking it.
Old 11-24-2013, 10:09 AM
rosskuhns's Avatar
Yes, that looks to be correct. Upstream o2 sensor is one that matters more, it's what the ecu bases it's 02 feedback (lean/rich) adjustments on. The downstream o2 sensors are there just to confirm that the cat's are working.
The ecu checks that there is a different o2 reading from the sensor after the cats, which shows that they are working; if not, it kicks off a CEL for emissions.
o2 sensors are designed so that as they die/degrade they rich (better to be too rich, than a lean/engine damaging issue), so you're gas mileage/running should get better with the replacement of that one.
Old 11-24-2013, 11:01 AM
Graham Royls's Avatar
Default o2 Sensors etc
Is there a single source to find the base/limits for the settings of the o2 and lamda sensors in a manual.?
Am specifically looking for 2001 XJR paramaters .
Is there a source that shows all operating parameters ?
Be nice to see a parameter list with green for normal /acceptable and red for replace .
Perhaps one of the great gurus of this forum can assist
Old 11-24-2013, 05:02 PM
meirion1's Avatar
You can buy a ring spanner with a slot in it for O2 sensors.
I suspect an open ended spanner will not do the job.
Old 11-25-2013, 01:52 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
You've got red via the fault code. There are no settings or adjustments other than in the factory as the sensor is made. They have to stand about 600C.
Old 08-15-2016, 11:19 AM
jackra_1's Avatar
Received 1,755 Likes on 1,326 Posts
Default Oxygen sensor renewal?
So even tho no fault codes I am contemplating replacing my upstream O2 sensors on my 2005 XJR at 106,000.
At this mileage is it a good idea or not?
Without taking my undershield off the car to look is this an "easy" job with the correct tool?
On my Dodge truck it was absolutely not an easy job until I found the correct flexible open wrench.
Are the two sensors identical?
Old 08-15-2016, 11:38 AM
Box's Avatar
Box
Box is offline
Yes, at 100k it is about time. Both upstream are the same, both downstream are the same, but upstream and downstream are different. Use Denso only.
jackra_1 (08-15-2016)
Old 08-15-2016, 11:45 AM
jackra_1's Avatar
Yes I was planning on using Denso.
Old 08-16-2016, 10:08 AM
rosskuhns's Avatar
Default yes
many mechanics (myself included) consider 02 sensors to be wear items. about 100k is the general life of one.
The interesting thing is that they are designed as they wear out to read to the rich side, so replacing them often will up your gas mileage (or more realistically bring it back to where it used to be).
The following 2 users liked this post by rosskuhns:
jackra_1 (08-16-2016), meirion1 (08-17-2016)
Old 08-17-2016, 11:29 AM
Gerry1's Avatar
Default Lamda sensors
Greetings. Same problem with my 2002. X Type. 2.5.
I was told the lamda sensors can be found on the exhaust.
I need two Lamda sensors myself.
Gerry
Old 05-21-2018, 01:52 PM
blairth's Avatar
Default 2004 XJ8 Upstream O2 Sensor 1647 code
I found many responses to other years. It appears that previous models were different and much more difficult. This was probably my easiest repair ever on this car. Put up on ramps, rolled underneath and the sensors are right there. There was even enough room to use a simple crescent wrench with a little extension for leverage. Came right out. As was mentioned elsewhere, the hardest part was being gentle with the plastic wire connector. They are brittle and can easily crack. 20 Minute repair once I figured it out. This repair sure does not justify the costs mechanics are charging for it.
J.A.G. (12-05-2021)
Old 07-11-2020, 01:46 PM
Clapton7's Avatar
Old 02-19-2022, 12:10 AM
PT950's Avatar
Default O2 sensor replacement
My XJ8L X350 is at the time where all the faults are coming in thick and fast. I have to replace both my upstream O2 sensors, have searched and there are not much photos of where the real location is, only technical drawings so here it is.
As another member has mentioned it is really a piece of ......cake to tackle and not worth the $100 and up of mechanics wanted to charge.
I stuck my car on a ramp, loosened the back end of the lower splashguard to have a bit more room and is literally in your face.
You have to pull or slide the grey connector towards you(see pic A) as it is held on with a sort of spade connector (see pic Z) and push down on the other side of the grey connector (see pic Y) to disconnect.
Then I used a O2 sensor removal attachment and replaced both sides which took less than 30mins for both sides.
So far these 2 months I have replaced all 4 air suspension units, rear parking sensor, ABS sensors and now thinking what is wrong with the suspension as it is rock solid which it wasn't before replacement of the shocks....tally ho
Pull or slide towards you to remove the connector attached to the support
Location on the left side, the right side is the same
Push and pull to remove the O2 sensor from the connector
This is the slide(spade) attachment to the body
My job done and money saved for the next jobs
Old 03-13-2022, 10:49 AM
J.A.G.'s Avatar
Default Question...
Thanks for posting this process. I'm having the p1646 code pointing to the bank 1. I'm confused on which one it is. The one on the driver side or the one on the passenger side.
Another thing, what made you replace them? It was just a code or did you actually felt something wrong with the car?
Old 03-14-2022, 10:20 AM
PT950's Avatar
Hi there,
I had the same code as you for both banks and also the exhaust fumes smelt a bit rich hence needed to change them, other than that the car ran ok. I think bank 1 is on the right hand side of the car(correct me if I am wrong)
RGPV6S
01-26-2021 12:19 PM
MattArnold
04-09-2020 07:33 PM
etaent
09-28-2017 12:32 PM
Jrp79
04-30-2017 09:09 AM
ABoxley
06-20-2010 08:06 AM
Quick Reply: Bank 2 Upstream 1 Lambda / O2 Sensor location
