having a problem w my alarm need help.....
Old 05-14-2012, 02:47 PM
Jsedita74's Avatar
Default having a problem w my alarm need help.....
my alarm has quit working. It stopped for a few day then magically started working again and now has stopped working again. I had the battery replaced to no avail.... Any info in the right direction would be great... thank you chaps.....
Old 05-15-2012, 05:19 AM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
How do you know it's stopped working ? No flashing alarm light on the dash top ?
Old 05-15-2012, 11:58 AM
Jsedita74's Avatar
Default Well when I press the buttons on the key fob
Nothing happens. Where should I start my troubleshooting? I already tried replacing the battery on the key fob.... Thank you for your time sir
Old 05-15-2012, 01:34 PM
Hi Jsedita
Nothing happens.
Please take me through what you expect to happen from the moment you lock using the remote, and I'll put my brain cells to work.
Old 05-15-2012, 01:50 PM
Jsedita74's Avatar
I'm sorry . Ok so when I hit the lock button it's supposed to flash the lights and lock the doors and fold the mirrors and vice versa. When I press the button absolutely nothing occurs. Again I'm sorry . Thank you for your time chap....
Old 05-16-2012, 07:01 AM
OK, first thoughts.
There are four buttons on the remote, do the others all work, (unlock, boot unlock, illumination on) ?
Try locking with key in the door and then unlock with remote, if this works it might indicate a new remote is needed . Do you have another remote, and if so, is this the same ?
Old 05-16-2012, 01:56 PM
Jsedita74's Avatar
Default Thank you
So I tried all the buttons on the key fob and they are all unresponsive . Doesn't look like the light on the dash is coming on either. I did notice that it stopped working for a few days and then mysteriously started working for a day or two and then stopped again. Driving me nuts. I finally worked out the suspension demons and now this .... Thanks chap
Old 05-17-2012, 03:12 AM
OK another. Does your second key remote work, or have you only one ?
Either the remote has packed up or lost its settings, or the receiver in the car has. It has to be one or the other. Delay in putting a new battery in can cause the remote to lose its settings. I believe there is a means of resetting it somewhere. Only a dealer can really check out your remote.
Old 05-17-2012, 04:02 AM
Jsedita74's Avatar
I don't have a second remote only the green valet key and when the guy went to replace the battery he tested my old one and said it was fully charged. Gave him a reading of 3.6 on the meter so it's fully charged
Old 05-20-2012, 02:54 AM
Jsedita74's Avatar
nothing chaps?
Old 05-20-2012, 06:32 AM
Suggest you get key checked out at a dealer
do the cheap checks first
Old 05-24-2012, 12:37 AM
Jsedita74's Avatar
I just noticed that when I lock the door with the key the light in the dash flashes.. What exactly does that signal?
Old 05-24-2012, 12:38 AM
Jsedita74's Avatar
Default Help
I just noticed that when I lock the doors with the key that the light on the dash flashes . What exactly does that mean?
Old 07-29-2012, 10:53 PM
Jagcar120's Avatar
Hi, I have the same problem and I was wonderring if you ever got it fixed?
Bigvettefreak
09-06-2015 04:27 PM
mcdutch
09-04-2015 03:38 AM
philwarner
09-03-2015 10:14 PM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: having a problem w my alarm need help.....
