Jaguar ACM Audio Connectivity module ipod interface installation photos
Old 05-06-2014, 12:03 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
I found the 'updated' CD emulator functions in this Denison user manual. I wondered what those other CD functions did.
Full user guide attached. Here is a snippet of those CD functions. I hope this helps others as much as it did me.
Attached Thumbnails Jaguar ACM Audio Connectivity module ipod interface installation photos-acm-upgraded-firmware-cd-emulator.jpg   Jaguar ACM Audio Connectivity module ipod interface installation photos-acm-upgraded-firmware-cd-emulator-sources.jpg
File Type: pdf
  #142
Old 08-01-2014, 02:23 AM
gclovaas's Avatar
Thumbs up Monumental production
Originally Posted by seamagineer
The attached PDF file shows photos of my ACM install in a 2008 Super V8
Its been installed for 5 weeks and I have had no issues with it. Currently only using it for an aux input for my satellite radio, hope to hook up an iphone soon.
WOW!! Herculean and sophisticated effort with a compendium of documentation. As a surgeon, I commend you on your dexterity.
Congratulations and cudos.
Greg Lovaas
seamagineer (03-03-2015)
  #143
Old 09-01-2014, 06:29 PM
Torrid's Avatar
So I finally stumble across what's going on with my car. I found the CD changer wasn't working and I just found the integration cables in the glove box. So I'd have to remove the ACM to regain changer function? I'm not going to, I think I may actually use the ACM. Question though, if I get a lightning adapter for the 30 pin, will a later iPad or iPhone 5 work with the system?
  #144
Old 09-02-2014, 05:25 AM
MoscowLeaper's Avatar
There's a switch on a ACM aux input. If you turn an ACM off by this switch the system will revert to the CD-changer functions after a restart.
  #145
Old 09-02-2014, 07:27 AM
gmcgann's Avatar
Not sure what integration cable you mean, but to test the cd changer, turn the car off, flip the switch on the ACM, then restart the car. You should now have CD changer instead of ACM. The car has to be off for the switch to work. Your iPhone will work, but except for stepping through the tracks/playlists, you'll have to control it from he phone.
  #146
Old 09-02-2014, 07:32 AM
Torrid's Avatar
It looks like I'll have to pull out the glovebox then. The 30 pin is coming out of the glove box opening.
  #147
Old 09-02-2014, 09:47 AM
Torrid's Avatar
Just found it. The module was mounted inside the glovebox too to the bottom of the upper opening. Flipped the switch and everything works. Man I did great with this VDP. I have one bad TPMS sensor and that's the only fault. Brilliant car.
  #148
Old 05-18-2016, 01:27 AM
Slobodan Popovic's Avatar
if i use ipod or iphone on acm module, can i switch tracks with command on sterring wheel or i can only listen music playing from iphone ?
  #149
Old 05-20-2016, 12:38 PM
jahummer's Avatar
Received 2,241 Likes on 1,410 Posts
Yes, you can use the steering wheel controls. It is a full integration.
  #150
Old 09-25-2016, 06:37 AM
flyrr100's Avatar
I have a 2002 X Type and bought a second hand ACM. Fitted it in about an hour. I use it for a Sirius radio fed using the RCA jacks. I did update the firmware because when I used to listen to my iPhone it wouldn't let me control it through the phone. The firmware fixed that.
The Sirius power was fed to an empty fuse in the box under the dash. I had a lot of engine noise but two in-line noise reduction things took care of that. I used the strips shown to connect to my ashtray. It demolished the ashtray, but fits well. I had to have my local Jag guy re-program the radio to recognize the ACM. That took around 5 minutes!
I'm buying a 2004 XJ8 and plan to take the ACM out and install it into the new car. Hopefully the install will be as straight forward as the X Type.
hafren
08-30-2023 03:42 PM
DrScientist
12-09-2015 07:36 PM
ControlIssues
09-03-2015 07:38 PM
Kristian_TT
08-28-2015 02:32 AM
meirion1
08-27-2015 01:04 PM
Quick Reply: Jaguar ACM Audio Connectivity module ipod interface installation photos
