Leak in the boot X350
Hi there,
I've got an incredibly irritating leak on my 2006 XJ, and am really hoping someone can help me. I have posted this on the UK forum but thus far to no avail. All attempts have failed.
So...here is the story so far:
Discovered there was rain water in the boot floor - the floor carpet was soaking wet, the battery and air compressor were soaked and there was about a litre of water sat in the wheel well.
Dried it all out and started the painful process of trying to find out where it was coming from. Long story short, the leak is actually not the boot itself, but that is the lowest point where the water is ending up. It is coming from above the right hand side rear wheel arch! So, using a hosepipe I have fully tested the boot and it is completely water tight. When I pour the hosepipe over the rear window, that's when the leak starts. Further testing shows that if I concentrate the hose on where the window meets the door, no leaks occur. But, if the water is concentrated on the trim area that goes round the door, that is when it leaks. I have pulled the trim off to see if there is a huge hole behind it but there is nothing! So, what am I missing guys? How on earth is water penetrating the body of the car and leaking through and into the boot.
Any help appreciated, it's driving me absolutely crazy!!!
I found a link to something that perhaps is what you are referring to and I explored all the options but to no avail. They included a leaking light cluster, leaking boot rubber and leaking through the bolts of the boot lid. I looked into each of these and it's definitely not those, it's for sure coming from the upper right side of the boot space, from a little metal ledge above the wheel arch.
This picture shows the exact point of entry into the boot, it's a case of figuring out how the water is penetrating the body of the car to get here! Such a frustrating problem.
leak
Ok for my next suggestion:
It is surprising how much water will get through the tinyest of holes and I think that you said at an earlier point that you have checked the bolts on the boot hinges and that they were tight but does this mean that they are watertight?
Is it possible that this is the source of the leak?
Odd location indeed, my friend. Can't agree more!!!
Rear Window gasket is perfect, no issues there.
Poured water all over the rear window and there is no issue whatsoever.
Have I been rear ended? I cannot be sure, certainly not during my ownership but that's only a few months. There is no obvious sign of rear end damage/repair.
Failed seam? Not that I can see, where specifically would I be looking?
On that subject there is a seam which runs left to right across the rear of the car but only an inch or two above the floor of the wheel well.
I had water leaking there when I was a bit over enthusiastic with a hose, but in this case you have water coming down from above and water doesn't usually go uphill!
Real what about using one of these?
Fibre Optic Inspection Scope | eBay
""But, if the water is concentrated on the trim area that goes round the door, that is when it leaks""
Please post picture of area if possible
Received 1,007 Likes
I think I've found it!
There is a seam which can be viewed once the lid to the boot is raised. it is slightly forward of the mount point for the hinge, on both sides of the car, in the 'drain channel'. It was interesting to see that there was a 2mm gap between the lower and upper plates! And the opening of this seam is facing the wrong direction!! It faces forward, counter to the draining direction! Imagine if water froze in there.
I will be sealing this gap myself. If I can manage it, I will take pictures, today as well..
mr merion - that scope thing looks like a brilliant idea! thanks for the link, if i get desperate i will investigate that.
912guy - i have used some sealant tape (i had some in the garage, it's the same type of thing as sealant but used in bathrooms around the base of a sink or toilet where it meets the floor). i've been enjoying the rare sunshine in england so have not fully tested the results but an immediate hosing didn't lead to a link.
guy - thanks very much for taking the time to take those photos. i had already spotted that issue on mine and have already sealed it up. it was actually one of the first things i spotted when i was first investigating the leak, so got it sorted immediately. unfortunately, this means that it is not the issue.
i will update this post once it's rained a bit (not normally a long wait over here!) or i get time to get out with the water hose again but i'm going to denmark for a few days so will have to wait now.
cheers everyone, this seems like a real good site with good active helpful members
Update: My 'fix' has not fixed the issue...
But...I have done further testing and absolutely categorically, without the doubt, the issue is down the rear side window, in the door shut area.
I know this, as I directed water ONLY at the rear side window, aiming it direct at the little window trim that sits above the side windows (I assume to catch the water and direct it away). I concentrated on the extreme rear of the car, and very soon there was water trickling in and appearing in the boot. So, I now know that's where my issue is. So I think I need to remove all trim in the door shut and the window trim, all rubber covers and seal the entire area up with some sort of silicone sealant, then put the trim back over the top.
I will not be beaten by this stupid problem!!!
Sorry never got round to taking any pics, I was too busy squirting a ton of silicone sealant/adhesive under the trim and all round where the holes are in the door shut.
Have to leave it to set for 72 hours so will test it tomorrow and report back. Typically, and I must not complain, the UK has great weather forecast for the next week so I shall have to make my own rain!
