Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ ( X350 & X358 ) XJ6 / XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X350 & X358 ) XJ6 / XJ8 / XJR 2003 - 2009
LinkBack Thread Tools Search this Thread
Old 09-06-2012, 05:02 AM
Untitled
It's odd, because I have never had a drop in my boot, except when I lift the lid with a load of water lying on it. Now I use a windscreen squeegy first !
__________________
Fleet manager of: -
XJ6 Sport 2003 (X350)
MG Midget 1977
VW New Beetle 2001 (wife's)
Fiat 500 1.2 Sport 2009 (daughter's)
Old 09-07-2012, 08:13 AM
Rael's Avatar
haha yeah I get that too! The design means that if it's rained (and it does that a lot here!) the rain sits on the boot then drips in when it's opened.
__________________
2006 X350 XJ 2.7d Sport Premium
Old 09-07-2012, 06:32 PM
guy guy is offline
I don't understand. It leaks into your boot from the rear passenger door, 1/4 window?
__________________
Guy Pensa
Cars with Personalities
2004 XJR (Jaguar Raging Green)
2002 S-Type R (British Raging Green, of course)
1951 Riley RMD (Black, time for that restoration)
Old 09-07-2012, 08:59 PM
I think the leak is in the gutter around the window ie part of the roof.
Old 09-09-2012, 04:25 PM
Rael's Avatar
I don't understand either mate, join the club!
Categorically, without a shadow of a doubt, the leak is starting from the rear window trim. I think the actual point of penetration into the bodywork, and therefore into allowing the water to find it's route to the boot, is by the trim that is in the door shut of the rear door. If you have an X350, open your rear door and half way down you will see a rubber bit of trim - i can only assume the leak is under there. I have pulled it all off and squirted in approximately 1/2 ton of silicone sealant and still the leak persists.
I am at my wit's end - and I'm heading to the US for 2 and a 1/2 weeks this Thursday so it will sit on my drive allowing lots of rain to drip into the boot.
I seriously might have someone weld up the rear door soon!!!
__________________
Old 11-19-2012, 12:50 PM
Rael's Avatar
OK guys - it's been a long time and would you like to know how much progress I have made? Zip. Diddly squat. Zilch. Bugger all!
Nothing I try has any effect at all. I have tried sealing over a weld in the outer boot (where rain water naturally goes) as it looks like possibly water could get in, but that's made no odds. I have even sealed all round the window trim on the outside, with no difference. I sealed all underneath the trim with windscreen sealant (thanks Mr National Windscreen dude for giving me a pack of the sealant!).
I am at the end of my tether with this, I really really don't know what to do so I am looking for some "next step" advice. Who/what type of person/company can I turn to for help with this? Jaguar say they will systematically go round changing all nearby seals in the boot, doors and windows which will cost a fortune (I reckon 4 figures easy). Perhaps a local garage? Or a bodyshop maybe? My fear is though, is that they, along with me, will not be able to fathom the cause of the leak and therefore won't be able to help!
Arrrrrrrrrrrrghhhhhhhhhhhhhhhhhhhhh!
__________________
Old 11-19-2012, 01:02 PM
Untitled
Very odd !! If you're in England, you could come over to my place and we'll jointly have a look. I have a hose on permanent standby. Location is near Crewe.
I assume no sunroof.
FFM
__________________
Fleet manager of: -
MG Midget 1977
  #28
Old 11-19-2012, 04:31 PM
Rael's Avatar
Odd is so not a strong enough word!! Very kind offer Mr Fraser dude but Crewe looks like a bit of a trek from Gatwick.
Correct, no sunroof, just a completely normal XJ, that looks totally ordinary, but for some reason can't stop sucking in rain
__________________
Old 11-19-2012, 04:57 PM
Default Leak in the boot X350
Our sympathies are with you Real.I hate water getting in a car.
Is it possible to route the water out of the boot as a temporary measure by funneling the water into a plastic tube and drilling a hole in the boot floor or somewhere suitable?
You never know, if you could make a good enough job of that it could be long term fix and maybe you could replace the boot liner?
My other point is maybe you have to remove the rear seat and start drilling holes (using a hole saw) into the inner body panels in the areas where you think the water might emanate from.
If you start drilling holes be very careful!!!!
  #30
Old 11-20-2012, 05:26 PM
Rael's Avatar
Thanks Meirion, I am on the verge of having myself put in a padded room lol
Believe me I have contemplated creating an escape channel for the water. In essence just diverting the problem. It may well come to that but I am still going to try and find a decent solution to the actual cause.
I see your point on the rear seat, this may well be a good idea and I shall put that in my back pocket for an absolute last resort due to the workload involved.
Cheers though, appreciate your thoughts!
__________________
  #31
Old 11-21-2012, 07:34 AM
Here is a Jaguar TSB regarding potential water leak areas. Maybe this will help.
Lcmjaguar
2008 VDP
1988 XJ6
  #32
Old 11-21-2012, 07:40 AM
Lcmjaguar
2008 VDP
1988 XJ6
Click the image to open in full size.
File Type: pdf Possible Causes Of Water Leak In Trunk TSB 2005.pdf (508.7 KB, 40 views)
  #33
Old 03-10-2013, 04:10 AM
Default Same problem.....
Hi
I see you live near Gatwick. I live 10 mins from there in Worth. I have the same problem with water ingress into my boot. Did you manage to fix the problem and would you mind letting me know what you did.
Dave
Quote:
Originally Posted by Rael View Post
Hi there,
I've got an incredibly irritating leak on my 2006 XJ, and am really hoping someone can help me. I have posted this on the UK forum but thus far to no avail. All attempts have failed.
So...here is the story so far:
Discovered there was rain water in the boot floor - the floor carpet was soaking wet, the battery and air compressor were soaked and there was about a litre of water sat in the wheel well.
Dried it all out and started the painful process of trying to find out where it was coming from. Long story short, the leak is actually not the boot itself, but that is the lowest point where the water is ending up. It is coming from above the right hand side rear wheel arch! So, using a hosepipe I have fully tested the boot and it is completely water tight. When I pour the hosepipe over the rear window, that's when the leak starts. Further testing shows that if I concentrate the hose on where the window meets the door, no leaks occur. But, if the water is concentrated on the trim area that goes round the door, that is when it leaks. I have pulled the trim off to see if there is a huge hole behind it but there is nothing! So, what am I missing guys? How on earth is water penetrating the body of the car and leaking through and into the boot.
Any help appreciated, it's driving me absolutely crazy!!!
  #34
Old 03-10-2013, 08:43 AM
peddlarbob's Avatar
Quote:
Originally Posted by Dave Fisher View Post
Hi
Dave
Dave I went through this whole frustrating process when I first got my car. Just as the original poster had done I used a water hose to soak everything trying to find how the water was getting into the trunk/boot area. No luck whatsoever.
Finally gave up and came close to drilling hole to be able to control the amount of water I was carting around. I then discovered my rear lights were loose. One was actually missing a bolt. So I tightened them up and found this totally stopped the ingress of water into the trunk/boot area.
Thankfully I had never got around to drilling the holes.
BTW I lived in Worthing, well Lancing actually just before I emmigrated over here to Canada.
__________________
Bob
2005 XJ8 Fully optioned VDP.
66,000 Klms.
  #35
Old 03-22-2013, 12:45 PM
Hi
Dave
Bob
I'll give it a go at the weekend....
Dave
  #36
Old 03-25-2013, 01:07 PM
peddlarbob's Avatar
Bob
Dave
So how did you get on during the weekend Dave ?????????
__________________
Bob
66,000 Klms.
  #37
Old 04-21-2013, 06:05 AM
Default Huge amount of water in boot
I have exactly the same issue, I just pulled out the spare wheel yesterday to find about 6 inches of water in the wheelwell, amazingly the car had still been driving and operating normally even though there was a significant amount of condensation on the battery cables and on all exposed metalwork. I haven't had the chance to investigate yet but I'm watching this page with anticipation.Rgds
Bob
Tags
2002, amplifier, black, jaguar, leaks, open, rear, seams, test, trunk, type, uk, upgrade, water, wheel, window, x350, xj350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
