Park windshield wipers in vertical position?
Old 02-09-2011, 08:52 AM
diverguy's Avatar
Question Park windshield wipers in vertical position?
Hi,
it's been freezing weather down here in Texas and one thing I always do then is to move the windshield wipers away from the windshield so that they won't stick. But with my '07 XJ8, I can't seem to make them stop in the vertical position - they always go down to the parked position - even if I turn off the ignition at the right moment. And since they can't be moved away from the windshield in the parked position, I'm "stuck" :-(
Is there a way to make them stop in the vertical position?
Rgds,
Mike
Old 02-09-2011, 10:35 AM
amcdonal86's Avatar
I've often wondered this. Ironically, the wipers often stop in the middle of the windshield when I don't want them to (intermittent mode).
Old 02-09-2011, 04:48 PM
twotone's Avatar
Stick a couple pieces of waxed paper (or aluminum foil) between the wipers and windshield.
Old 02-09-2011, 07:43 PM
amcdonal86's Avatar
What is that supposed to do?
Old 02-10-2011, 08:24 AM
diverguy's Avatar
I assume that would stop the wiper blades from sticking to the windshield - will most likely not work if there's sleet/snow though... I've used CD cases to keep the wipers of the windshield (angled so they are not laying flat against the windshield - wouldn't work then ;-).
/Mike
Old 02-10-2011, 08:37 AM
amcdonal86's Avatar
Oh, sorry, I thought you were trying to get them in the up position to change the wiper blades. Does anyone have any idea how to do that?
Old 02-10-2011, 12:02 PM
diverguy's Avatar
Well, the original question was how to stop them in the vertical position so that I can angle them out away from the windshield so that when it's freezing weather with sleet/snow, they will not freeze and stick to the windshield...
twotone just came with an alternative solution - in the same way I've done it...
The original question hasn't been answered - and it might not be possible to have them stop in the vertical position...
johndahlheimer
09-17-2020 03:10 PM
HypnoGuru
10-23-2018 09:53 AM
Rlover
03-30-2016 10:04 PM
CaneCounsel007
11-13-2015 09:05 PM
1964Daimler
09-09-2015 11:28 AM
Quick Reply: Park windshield wipers in vertical position?
