Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X350 & X358 ) XJ6 / XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X350 & X358 ) XJ6 / XJ8 / XJR 2003 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 01-19-2012, 10:02 AM
usmc1211's Avatar
www.facebook.com/JaguarAutoOwnersGroup
Cool Rear Parking Assist
Hey, maybe someone has the same problem. When I first bought my XJ8, the parking assist did not operate. A couple months later, it started to work perfectly out of nowhere. About 6 months ago, it stopped working again. I checked the fuse and it was blown. I replaced it and the system is still not operating. Any troubleshooting tips would be great. I do not know where the module for the system is. I know a general area, I suspect near the rear wind screen, right hand side, behind the seat. I only figure that because when it was working, that was where the "beeping" noise was coming from. Help please.
Old 01-19-2012, 03:27 PM
oldmots's Avatar
Mine just stopped working so I looked into it a little. Put the car in reverse and listen to each sensor to see if it is clicking. If no clicking, that sensor is bad. If all click and there is no code, the speaker under the parcel shelf might be bad. If there is a code, the module behind the rear seat back may be bad.
__________________
05 XJ8 4.2
04 Audi A6 Quattro 3.0
06 XKR Coupe
04 Jeep Wrangler
09 Kawasaki Concours 1400
65 BMW R69S
67 Velocette Venom Thruxton
89 Honda GB500TT
Old 01-19-2012, 04:24 PM
Banned
Didn't know they clicked.
Old 01-19-2012, 08:36 PM
motorcarman's Avatar
Photobucket
The reverse parking aid module is on a network and fault codes can be 'read for current content position' as Jaguar calls it.
The system is SONIC so they do pulse a 'click' that can be felt with a soft touch of your finger tip or listened to with a stethoscope.
The speaker can also fail so you don't hear the sounds even though the system is operating correctly.
The early X100 and X308 systems are 'STAND ALONE' and are NOT on a network.
bob gauff
__________________
Owning and repairing British and German cars since the early 70's
2001 XJ8 Mistral
1999 XJ8L Topaz
1985 XJ6 Belgian Import (Gray Market project car)
1985 XJ6 (Parts Car)
1983 XJ6 (Parts Car)
1992 Sovereign (sold)
2001 S-Type 4.0 (sold)
1997 XJ6L Black (sold)
1997 XJ6L White (sold)
1972 XJ6 (sold)
1966 'E'Type (first Jaguar) (sold)
Old 01-19-2012, 09:37 PM
reyesl's Avatar
The module is located in the trunk/boot, just to the rear of the spare tire.
Rear Sensors only: C2C20921
Front and Rear Sensors: C2C20922
Rear Parking Assist-park-aid-module-1.jpg   Rear Parking Assist-park-aid-module-2.jpg
__________________
Construction Equipment Maintenance Instructor
2004 VDP
2004 X-Type
2006 Expedition XLT
2000 Durango SLT
2007 Jeep Liberty
Old 01-20-2012, 04:56 PM
usmc1211's Avatar
Okay. So, I checked out the clicking sound. It is there. I can hear it very well. I checked out the module and everything seems good to go. I got to the speaker for the system and it had no input to it. I put the vehicle in reverse and used my multimeter to check and see if there was a voltage input to the speaker. There was nothing. Any tips?
Old 01-20-2012, 05:41 PM
reyesl's Avatar
Part of the workshop manual, will add more when I locate it.
Was there an obstacle to set of the Park Aid while you checked for voltage?
__________________
2004 VDP
2004 X-Type
2006 Expedition XLT
2000 Durango SLT
2007 Jeep Liberty
Old 01-20-2012, 06:19 PM
Banned
Quote:
A digital multimeter probably wouldn't show anything. Try using a known good miniature speaker.
Old 01-21-2012, 09:39 AM
usmc1211's Avatar
Thanks for the insert from the manual. I did more troubleshooting and there is no output from the systems module in the trunk. ?...
Old 01-21-2012, 10:56 AM
oldmots's Avatar
If the module has no speaker output, that would tell me it needs to be replaced. Since I don't know how it works or what type of output it should have, it's an intuitive call....whcih can be wrong in these days of fancy electronics.
__________________
05 XJ8 4.2
06 XKR Coupe
04 Jeep Wrangler
65 BMW R69S
89 Honda GB500TT
Old 01-21-2012, 02:38 PM
Banned
No output where? The module can't be dead or the sensors wouldn't click.
Old 01-22-2012, 09:02 AM
usmc1211's Avatar
I checked the wiring from the speaker, as much as I could, all the way back to the module. I checked the output from the module, using the pins that would output to the speaker and there was nothing. That is all I know. Now, I have seen where people are saying they act up if the sensors are dirty. Could that cause this issue? I'm stumped.
Old 01-22-2012, 02:48 PM
Banned
Describe how you "checked" them.
Old 01-23-2012, 08:38 AM
usmc1211's Avatar
I turned the car on, placed it in reverse. I went to the back of the vehicle and at each sensor, I listened for an audible clicking sound. Each had the sound. So, then I assumed that that part of the system was operating as it should. Next, I took the upholstered deck off, where the stock subs are, so I could get to the small speaker for the system. I checked the connection, no corrosion or anything of that sort. I connected my DVM (digital multimeter) to the pins in the plug, while the car was in reverse, I did not see any voltage there. I then attached a small speaker to the pins in the place of the cars stock speaker for the rear parking assist. There was no "beeping" sounds. Next, I had a friend help me, I ohmed out the wiring. Setting my DVM to ohms, I put one test lead on one end of the wiring, the end at the speaker, and the other lead to the appropriate pin at the control I/o (input/output) module, the little black box in the trunk. There were no opens in the wiring from the box to the speaker. Assuming the sensors were operational, and the wiring to the speaker and the speaker itself are good, I then assume that the module for the parking assist as faulted.
Old 01-23-2012, 03:44 PM
Banned
In order for the system to beep it has to detect an object fairly close. How did you simulate that>
Old 01-24-2012, 09:25 AM
usmc1211's Avatar
I backed the car up in my garage to where it was about 3 feet or a little less from the wall.
Old 01-24-2012, 06:50 PM
Banned
Max is 24 inches (60 cm) on the corners and 63 inches (160 cm ) in the rear. Have you checked for a stored fault code? Object has to be less than 12 inches for a continuous tone. Do you have front also?
You said you replaced a blown fuse. That may well mean the module had an internal problem. I assume the new fuse did not blow?
Old 01-25-2012, 07:13 AM
usmc1211's Avatar
I do not have front parking assist. I did replace the fuse and the new fuse did not blow.
Old 03-25-2012, 10:57 AM
Send a message via Yahoo to Clamdigger
Default parking assist
I have both front and rear parking assist on my 07 XJ8 and when I first put it in gear I get a 3 second tone. The manuel says it means a fault in the system, I was just going to live with it till I bring it in for 60K service but now it's going off alot when at trafic lights. I then have to manuely turn it off. Is there a way to just disable the system completely?
__________________
Barry NJ, USA
2007 XJ8 4.2L
2006 Mustang Conv V6
1999 GMC Serria 2500 6.0L- Hurricane Sandy took it to the graveyard
Tags
2004, aid, assist, car, jaguar, module, park, parking, rear, system, work, working, xj8, xjr, xk8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
