Removing exhaust tips on '07 XJ8
Old 04-20-2014, 07:56 PM
Rufus T. Firefly's Avatar
Default Removing exhaust tips on '07 XJ8
I want to remove the exhaust tips so I can clean/polish them, but from what I can see, it looks like they're welded in place. True? or is there an easy way to get them off?
Any input appreciated...
Rufus
Old 04-20-2014, 08:13 PM
rosskuhns's Avatar
they are almost surely welded on...you'll have to polish them in situ.
Old 04-20-2014, 08:39 PM
Damn, I was afraid of that
Old 04-21-2014, 04:52 AM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
Nope, they're held on with a single screw, but seem welded on after a couple of years of road filth has crept into the gap between pipe and trim piece.
I tried to remove mine. Took the screw off then found the damned thing would not move, so decided it's better just to get out a kneeling pad and polish in situ.
Old 04-21-2014, 07:05 AM
reyesl's Avatar
Same on my tips, they cleaned up great with a dish-washing pad.
Old 04-21-2014, 02:26 PM
Your pic shows the little securing screw too !
Old 04-21-2014, 02:27 PM
Okay, I'll have to go take another look
Old 04-21-2014, 02:36 PM
rosskuhns's Avatar
I stand corrected. Haven't seen a manufacturer put the screws on the tips in a long time.
Old 04-21-2014, 04:22 PM
50324XJ8's Avatar
Mine were only held on with the screw that was not easy to get loose.
Old 04-21-2014, 04:24 PM
I just took a much closer look and they are indeed welded on. One spot on the upper inside, and one spot on the lower outside.
bamforp
09-26-2021 08:04 AM
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
Jandreu
01-23-2017 10:58 AM
Daim
11-28-2016 09:28 AM
Quick Reply: Removing exhaust tips on '07 XJ8
