XJ ( X351 ) 2009 - 2019
Illuminated door sills
Old 11-17-2016, 08:09 PM
msp843's Avatar
Default Illuminated door sills
I just recently purchased a 2016 Jaguar xj l (love it) and am looking for some illuminated door sills. I've looked on ebay but haven't seen any that look like they will fit a 2016. Has anybody found any that will fit? Can you forward the link? Thanks in advanced
Old 11-18-2016, 01:08 PM
Thermo's Avatar
Received 3,822 Likes on 3,142 Posts
msp843, go to Jaguar Parts, put in your car information and from there, you can find the door sills under the body parts section. If I remember right, the plugs are already under the door sills that you currently have. So, getting them to work should be no issue. As for price, well, be ready for a shock.
Old 11-18-2016, 06:37 PM
Stuart S's Avatar
Received 6,131 Likes on 3,378 Posts
See my thread from last year: https://www.jaguarforums.com/forum/x...plates-153556/
They're "officially" called scuff plates in the Jaguar parts catalogs.
2016 XJL from: https://jaguarmerriamparts.com/parts...?siteid=215718
Part Number: C2D30454 Scuff plate, front, illuminated right: $189.12
Part Number: C2D30455 Scuff plate, front, illuminated left: $189.12
They don't show illuminated scuff plates for the rear.
I believe that the 2016 scuff plates are aluminum, which accounts for the significantly lower prices than in earlier models that were stainless steel.
For my 2013 XJ (short wheelbase), from: https://jaguarmerriamparts.com/parts...?siteid=215718
Part Number C2D22752 Scuff plate, front, illuminated right: $291.95
Part Number C2D22753 Scuff plate, front, illuminated left: $291.95
Part Number C2D22754 Scuff plate, rear, illuminated right: $284.11
Part Number C2D22756 Scuff plate, rear, illuminated left : $291.08
For the 2013 XJL, from: https://jaguarmerriamparts.com/parts...=scuff%20plate
Front, R&L are the same as the SWB, above. Rear are different.
Part Number C2D22755 Scuff plate, rear, illuminated right: $291.08
Part Number C2D22757 Scuff plate, rear, illuminated left : $291.08
Fronts are the same size for swb or lwb, but rears are different - longer for the lwb models.
I believe, but am not absolutely certain, that the stainless steel illuminated scuff plates from the pre-2016 model years will fit the 2016 model. To be certain, ask your Jaguar dealer.
Stuart
The following 2 users liked this post by Stuart S:
Chet Crouch (03-30-2017), Panthro (11-27-2016)
Old 11-18-2016, 06:59 PM
msp843's Avatar
Great info, thanks for your help!
Old 01-10-2017, 02:22 AM
Z20's Avatar
Z20
Z20 is offline
Will the 2016 illuminated door sills fit earlier XJ's or XJL's? That is a significant savings per door. And since I am planning on buying some very soon I would love to save a few dollars.
Old 01-10-2017, 11:23 AM
Stuart S's Avatar
I think they will, but check with your dealer to be sure. See my Post #3, above.
