XJ XJ12 ( X305 ) 1995 - 1997
P0410 code Jaguar XJ12 6.0 cylinder
Old 04-30-2015, 05:08 PM
edcp4k's Avatar
Smile P0410 code Jaguar XJ12 6.0 cylinder
I have a P0410 ... replaced vaccumn solenoid and delay .. I need some help from all experts and serious mechanics who could help out how to replace the air switching valve that connects to air pump. thank you
Old 02-05-2017, 08:40 AM
RFXJ12's Avatar
Did you ever sort out the P0410 code? I have started to get the same code on my 96 XJ12. It clears but returns a day later.
Old 02-07-2017, 01:25 AM
SleekJag12's Avatar
Doubtful. He's long gone from here. Apparently there was little help to be found from the "experts and serious mechanics" here! Lol
P0410: Air Injection failure.
Does the air injection pump run at startup, and cycle on and off while idling? If not, then the relay might be bad or loose. It is the one in the middle of the group of three, on the right hand side of the engine compartment, behind the right headlights. Also check the air pump fuse: F16 (red, 10A) in the right side engine compartment fuse box.
Check the air hoses coming from the pump, a breach in one of those could possibly cause a code.
Be sure the drive belt for the air pump is in very good condition or better. It is also the belt that drives the coolant pump, and we want to be sure that coolant pump always turns smartly!
The following 2 users liked this post by SleekJag12:
RFXJ12 (02-07-2017), smgdata (02-22-2017)
fast40driver
04-19-2024 07:24 AM
1100me
08-27-2020 11:37 PM
X_Type_South_Africa
12-09-2015 05:37 PM
1100me
08-31-2015 04:50 PM
1100me
08-28-2015 09:48 PM
Quick Reply: P0410 code Jaguar XJ12 6.0 cylinder
