Repair Questions 96 XJ12
I recently hit an elevated manhole cover and tore up the front suspension on my 1996 XJ12. If I buy another 95-99 XJ6 or XJ8, can I use the parts from that car on my XJ12? I am not sure if I needed to find another XJ12 due to the weight of the motor. The XJ12's are hard to locate in Florida if you want it just for parts.
Received 10,757 Likes
Looks like the control arms are the same as other X300s although different arms were used depending on VIN, not engine size.
The 'upright' snd spindle look to be the same
The front subframe is different than the 6 cyl cars....not sure how.
The springs are different becasue the V12 is heavier
So, 'some' of the supension parts are the same, others are not
Florida1996JaguarXJ12 (10-21-2014)
philwarner
09-05-2015 10:05 AM
