2004 XJ8 Headlamp bulb replacement
Old 02-15-2011, 06:45 PM
danimo's Avatar
Default 2004 XJ8 Headlamp bulb replacement
Does anyone know how to remove the clip that holds the bulb assy in the housing. It's a metal clip and kinda hard to get to.
Old 02-16-2011, 12:28 PM
roviw's Avatar
I had to do my nearside ( UK car) bulb yesterday, it can be a struggle but once you have popped the rear cover off and pushed it down and to the side you can use a flat blade screwdriver to hook the lower part of the wire clip to the side from where it is hooked behind a small piece of metal, once free, it can be eased upwards but left attached at the top edge, almost like hinging it out of the way.
Then ease the electric plug from the rear of the bulb and carefully pull the bulb out using the two metal blade terminals sticking out.
Refit the new one ( keep fingers away from the glass) making sure the "notch" is at the top, drop the spring clip back down and ease it behind the metal notch to hold it in place, replace the electric plug and then manipulate the rear cover back into place and reclip the other metal clip to hold that cover tight.
Hope this helps and is not too long winded but a lot of people really struggle to change the bulbs as it is such a tight area to get your hands into. I also use a tiny torch, usually held in my mouth ! haha to help as it can be a bit dark down there.
Best of luck.
Old 02-16-2011, 07:28 PM
danimo's Avatar
Thanks, I'll give it a try in the AM.
Best of luck.
Old 02-22-2011, 09:05 AM
relinuca's Avatar
See my post dated Feb. 11 for some perils.
relinuca
Kyd (02-29-2012)
Old 02-22-2011, 09:55 AM
kthrash's Avatar
Make sure when you reinstall the new H7 bulb to insert it with the tab pointed up.. it looks like it should point down but it really points up..
Old 02-29-2012, 09:06 PM
Kyd's Avatar
Kyd
Kyd is offline
Default RE: How to R & R 2004 XJ8 Head Lamp Bulb
Well Danimo... How did the R & R go? My passenger's bulb went out; so I bought a new one from Auto Zone for $16 (H7) and am ready to install... Sounds like a tricky & tight manouver. Wondering how your ordeal went?
Any caveots?
Kyd
NE Florida USA
2004 XJ8 Sea Frost Green
philwarner
12-06-2021 07:13 AM
rsmartin
39
11-12-2021 01:09 AM
Sprayall
05-30-2021 08:13 AM
Sprayall
09-03-2015 07:49 PM
Terencex
08-26-2015 08:47 AM
Quick Reply: 2004 XJ8 Headlamp bulb replacement
