Brake Rotors
Old 04-30-2010, 06:32 PM
weeruss's Avatar
Default Brake Rotors
I guess there are two types of front brakes on the '04 XJ8 - does anyone know how to tell them apart ? I just want to replace rotors and pads
Old 05-01-2010, 02:21 AM
BuckMR2's Avatar
Is it before or after Vin G49701 and is it supercharged?
Old 05-01-2010, 12:16 PM
weeruss's Avatar
The cars prior to G49701 and it's not supercharged.
Old 05-01-2010, 02:20 PM
BuckMR2's Avatar
There are 3 pads listed (10/2009)
C2C15990 supercession
C2C20686 supercession
C2C23786
Not sure what the supersession means (whether the 2 suspercession numbers are superceeded to C2C23786 or whether there are 3 current numbers the latest supercessions of which are listed for the initail 2 numbers)
Old 05-01-2010, 09:31 PM
hlgeorge's Avatar
I would go with after market ceramics on the pads. No brake dust. I used Brake Pads:
Front: AKEBONO Part # EUR1065
Rear: AKEBONO Part # EUR806
Got them from www.RockAuto.com
Brake rotors:
Front Rotors: POEF06471 - 120.61077
Rear Rotors: POER06471 - 120.61062
From www.r1concepts.com
Old 05-02-2010, 02:26 AM
BuckMR2's Avatar
Agree about using the aftermarket pads (assuming the part numbers in the last post are the same as your car) but I would go for the better EBC redstuff
Old 05-02-2010, 07:54 AM
steve11's Avatar
ud
I have ceramics on all my cars, and always recommend them...Ditto about the dust, performance....do it!
Old 05-02-2010, 10:55 AM
310jag's Avatar
I actually just ordered pads and rotors all around for my 05 L from AutoAnything.com. I went with centric premium rotors, EBC Redstuff pads up front, and a set of decent pads for out back. The grand total with shipping was only $368, so I was quite happy. I can get you the exact part numbers if you'd like.
Old 05-02-2010, 02:36 PM
BuckMR2's Avatar
Thought they changed 05-06 and then again 07-
If so 05-06 wouldnt fit
Old 05-14-2010, 10:46 AM
weeruss's Avatar
Thanks for all the info guys. Will put it into use
Old 05-14-2010, 11:02 AM
SVL77's Avatar
Looks like there are plenty of us changing our own pads/rotors...I will be doing this soon on my 2006 VDP.
I remember reading somewhere that there is a special tool required to compress the pistons in the rear caliper.
Can anyone confirm this?
Old 05-14-2010, 11:38 AM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
The OEM rotors are really well nice looking and not much if any more cost than the better aftermarket rotors.
The Akebono pads are great. Very little dust and very little stopping power compromise.
Old 05-18-2010, 06:45 AM
rothwell's Avatar
Received 1,252 Likes on 687 Posts
I am at 44K on my 2005 VDP and soon will need to do my brakes.
I am also interested in learning about the special tools/process to do the rear ones. What's so special?
Old 07-17-2010, 04:56 PM
equicor's Avatar
It's been a couple of months since you posed the question of the special tool. Did you ever get a response? I'm thinking of doing a brake change also.
Old 07-19-2010, 06:13 AM
rothwell's Avatar
No response here but I did some more research and think this is what we need:
http://www.harborfreight.com/18-piec...kit-97143.html
Old 07-19-2010, 09:23 AM
SVL77's Avatar
Correct. I purchased the kit in the link above and used it to change the rear pads...worked perfectly. The kit will come in handy for future work on other makes as well.
Old 07-19-2010, 09:59 AM
Drew's Avatar
Do believe the issue is the rear caliper piston screws in on the base models. My 04 XJR didn't, but I think the emergency caliper does.
Old 07-20-2010, 02:27 PM
equicor's Avatar
Thanks Guys!
What would an amateur do without this forum?
Old 09-20-2010, 10:29 PM
locorebob's Avatar
Default 06 brakes
Ken, I just acquired an 06 XJ8 that just had the rear brakes done. The shop replaced the rotors which I thought was unusual given my experience with working on cars. Did you do thye brake son your 06?
Bob
Old 09-21-2010, 10:17 AM
equicor's Avatar
No Bob, I haven't got into the brakes yet, but will have to soon. How's that new Jag ride?
Quick Reply: Brake Rotors
