When getting off gas and braking, transmission clunk?
Old 12-13-2010, 06:01 PM
amcdonal86's Avatar
Mine doesn't seem as severe as yours. Mine cures itself by using the sport mode (confirmed today).
Old 12-14-2010, 02:14 PM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
I have found it is possible to get harsh, "clonky" changes at low speed, such as braking for a RH turn, stopping momentarily, then immediately going onto the throttle to make the turn, can cause a clonk action.
I have assumed it is a feature rather than a bug, as I used to get ocasional similar changes with my Rover 75 which had a Jatco 5-speed autobox. So to relieve it, I am just more delicate on the throttle until I can feel the drive is taken up. Yes, I know, these things shouldn't happen !
Old 12-14-2010, 02:25 PM
amcdonal86's Avatar
The strange this is the clonk, for me, has little to do with any action I take. Rather, it happens when the transmission decides to go in/out of lockout mode (or at least that's my perception).
But yes, many of the things on this car have me saying that this car has a lot of features, not problems.
Old 12-17-2010, 05:45 PM
amcdonal86's Avatar
Well, it appears the clunking isn't solved by using the sport mode anymore. I think I will just learn to live with this noise. This is not a Lexus, it's not supposed to be whisper quiet and word-class refined! It a Jag! It's supposed to be about muscle, restrained elegance, class, etc.!
Old 12-18-2010, 04:16 PM
It could be worth getting a Jaguar specialist to test drive it with you in the passenger seat. If he says "they all do this" then you are OK. If there is a fault, it's best to know well before the box lets go.
Old 04-07-2011, 06:39 PM
jimmycruz99xjr's Avatar
Former Sponsor
I am experiencing the same thing but I have a 136k miles on a 1999 xjr am I in danger of the reflash?...could the transmission mount just be bad..I also tend to hear a clunk-at low speeds and also when letting off the gas.?
Old 03-25-2017, 09:12 AM
a6kmita's Avatar
I wonder if what I've been experiencing is similar?
https://www.jaguarforums.com/forum/x...-clunk-172536/
Mine mostly seems to emit a "clunk" noise whenever you engage or disengage the throttle - also occasionally when it is quickly upshifting after letting off the gas. I've noticed too that when going highway speeds, if you really lay into the gas and get a couple gear downshift it seems to "slam" into the lower gear. Does that sound similar to what an ECU trans update might fix? Or does that seem more mechanical? In the two years I've owned my car, honestly it hasn't gotten any better or worse. I've considered doing a trans flush but the dealer didn't feel it was necessary yet.
tomsjag
06-10-2023 10:02 AM
aholbro1
08-05-2021 05:02 AM
Razor
08-28-2019 08:34 PM
KarimPA
09-12-2015 08:15 AM
AtholC
09-09-2015 09:07 PM
Quick Reply: When getting off gas and braking, transmission clunk?
