96 xj6 over fueling
Guest
Posts: n/a
96 xj6 over fueling
can anyone please help? the jag runs great and starts good on first start up but once u shut it off and restart it floods its self. disconect the fuel pump fuse and restart the car u have enough time to replug the fuse in and keep it running. it is flooding on start up and over fueling wile running at any speed can any one give any ideas ??????
Coolant temp tensor? They do go wonky. Best way to check is get a scanner to check what temp it's sending to ECU. They don't cost much. The one that goes to the ECU not the one for the temp gauge. To clear a flooded engine, floor throttle, start cranking - maybe 20 seconds, then bring throttle to halfway. I beleive this method shuts of the injectors and alows a flooded engine time to clear the cylinders.
rusty37
04-05-2020 07:40 PM
pnwrs2000
01-15-2018 07:20 PM
