fog and side marker lights out
Old 07-29-2015, 03:09 PM
19jag95's Avatar
Default fog and side marker lights out
I can't figure out my right side fog and marker lights have stopped working I have checked all the fuses several times and all is good. Have looked all around but can't find anything. I figure that it might be a bad relay. I tried finding the location of that relay but I have not found anything. Where can I find the relay and what else should I look at. Hope someone can give me idea what to do.
Old 07-29-2015, 05:12 PM
al_roethlisberger's Avatar
Are you sure you are getting power to the sockets or not? Unlikely, but possible that both bulbs are loose or out. I actually had two of mine out, and sharp tap with my finger had them come back on!
19jag95 (08-01-2015)
Old 07-30-2015, 05:58 PM
19jag95's Avatar
Yes, the first thing was to change the bulbs, the next thing I did was to check the plug for power and there was none. I bought a bulb for that foglight and it was no good and shorted our again the ground. All the fuses are good so it's some ting in between. So I would like to find out where the relay for the fog lights is at and see if it fried it.
Old 07-30-2015, 11:32 PM
19jag95's Avatar
Okay, no answer is better than a wrong answer when it comes to wiring on a jag. I'll check the ground wires tomorrow and if that don't work, I'll take it to Audio Sound in Fresno, Ca. They are really good with electrical. But I don't like to spend the money, but they are cheaper than other places
Old 07-31-2015, 05:19 PM
ablack's Avatar
Tom,
From what you describe, it sure sounds like a ground fault. I am sure both fogs are on one circuit and both markers on another with separate fuses and relays, but I wouldn't be surprised if the lights on each side are connected to a common grounding wire.
Have you tried grounding one of your inoperative lights directly? I have a few wires with alligator clips at both ends which work great for this. They enabled me to identify an identical fault with my wiper unit.
Good luck!
Old 08-01-2015, 02:54 PM
19jag95's Avatar
I fixed it. Somebody had spliced the hot wire to the fog light and it pulled it apart. I put on a solder less connector on it and all is good now. Somebody must have needed a hot lead for something. And the side marker wasn't so easy. I finally gave up tracking the wires so I just spliced into the daylight bulb and cut the hot wire that was leading to the side rker.
All is working, I'm happy now
Don B (08-03-2015)
99xk8guy
06-05-2023 06:28 AM
Jpav27
07-31-2022 06:43 AM
mbergen
10-23-2019 10:26 PM
rsa760041
23
09-25-2015 01:33 PM
KarimPA
09-12-2015 08:15 AM
Quick Reply: fog and side marker lights out
