frozen radio
Old 10-12-2008, 04:55 PM
hlgeorge's Avatar
Default RE: frozen radio
Try the 'reboot' method. Disconnect the + battery cable for about 5 minutes. Touch the + cable to the negative terminal for just a second before reattaching it to the battery. Reattach the + cable to the battery. This will reset anything that has memory, so any memory dependant functions must be reset. This got my neighbor's radio working again.
Old 10-15-2008, 12:20 PM
Received 2,183 Likes on 1,355 Posts
ITS A COMMON PROBLEM, AND JAGUAR NO LONGER SUPPLIES REMANS FOR THIS ONE, EVEN LATER MODELS ARE HARDER TO FIND. i JUST REPLACED MY WIFES ENTIRE SYSTEM, SPEAKERS AND HEADUNIT FROM CRUTCHFIELD, WORKS GREAT AND HAVE IPOD, AND SAT NOW TOO
Old 05-12-2010, 05:12 AM
sogood's Avatar
Default Re; Reboot
I have used the "reboot" procedure in the past on my 1990 BMW 735, but have left the terminal leads connected together for up to half an hour or longer. It usually tends to remove any "bad" memories and one of the more noticeable improvements is that of a smoother gear change in automatics. It's a procedure that sometimes has to be repeated, as the management system tends to "remember" the cars old bad habits again after a while. Costs nothing and worth a look see. On the issue of a frozen radio, I also have this problem on my recently purchased 1997 x300, only that it's frozen off. Dead as a dodo, although it has power and an earth, as does the antenna. I keep reading about a (brown) radio relay, but despite numerous searches cant locate it. Some posts suggest that it lurks behind the glove box, others mention behind the drivers kick panel at the right side of the steering wheel. I have searched both but to no avail, so, does anybody, pleeeeeaaasseeeeeee have a clear, exact location for this mystery item? many thanks
Old 01-27-2013, 07:40 PM
My 96 vanden plas radio is frozen also?? Did anyone come up with a possible diagnosis?
Old 01-27-2013, 07:46 PM
Jagfixer's Avatar
You can go to the dealer with title of owned car and receipt for used radio and radio model and serial #s then they should be able to give you that radio's code. Blank screen does need code on the modern secured radios.
Old 01-27-2013, 07:57 PM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
Except USA-market "X300" Jags. No codes used on those :-)
Old 10-01-2018, 04:03 PM
Jimi Shelter's Avatar
No codes for US market 1996 X300 XJ6 ?
That's good news.
I'm thinking of doing a hard reset.
The radios crap anyhow.
I can't see how I'm gonna find another stereo to fit that shape of an opening, though.
Any ideas?
Old 10-01-2018, 04:17 PM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
There are 3 fuses for the Jaguar / Alpine AJ9500 stereo head
Editing after lunch
Paora
02-04-2021 12:36 AM
philwarner
01-31-2016 09:36 AM
MrWhite
33
10-22-2015 10:29 AM
ziondio
09-28-2015 11:24 AM
Quick Reply: frozen radio
