HELP EGR tube thread tap issue
Old 08-29-2015, 01:40 PM
SD96XJ6L's Avatar
Default HELP EGR tube thread tap issue
I needed to replace my exhaust gaskets coming from the manifold to the down pipe before the pre-cats. Everything went ok, but when I went to put the EGR tubes back on, one of them will not thread back in and is slightly stripped. ARGH! What do I do? Anyone know of a solution? Thread repair kit? It's a 17mm head the same as the 02 sensors. Any input would be great!
Old 08-29-2015, 02:08 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Is what you refer to as "stripped" the first thread on the thread nut, or is it the thread in the body? Use a triangle file to clean up the one on the nut. I have no idea for the one in the manifold.
Old 08-29-2015, 03:07 PM
RJ237's Avatar
Received 2,781 Likes on 2,225 Posts
Make sure it's really stripped and not just misaligned. Getting a nut to start when the pipe is pushing it slightly is very difficult.
Old 08-29-2015, 03:20 PM
SD96XJ6L's Avatar
It's definitely stripped a bit. The thread is laid down. A triangle file is a great idea. Thank you.
JarodL
03-07-2024 01:39 AM
kelliott
05-31-2022 05:26 PM
Kevin Burnaby
06-28-2020 08:04 AM
SteveSheldon
UK & Eire
09-08-2015 11:22 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: HELP EGR tube thread tap issue
