Oily film inside windows???
Old 06-30-2016, 08:34 AM
John Dobbins's Avatar
Default Oily film inside windows???
I have an odd issue with 97 XJR. There is an oily film coating the inside surface of all my windows, is worse on the front side windows but is also present on windshield and back glass. If I clean the glass it is clear for a day or two then the build up returns. Has anyone else experienced this problem? Any ideas what may be causing it? Suspect it could be from the AC system but think that if was refrigerant oil from AC leak the system would be out of refrigerant by now.
Old 06-30-2016, 05:55 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Are you sure your olfactory system is working? I suspect it is ethylene glycol from the heater matrix.
Old 06-30-2016, 11:51 PM
Doug's Avatar
Received 10,741 Likes on 7,097 Posts
If the heater core isn't leaking then I strongly suspect you're seeing the results of 'outgassing' from the interior plastics/vinyl.
I had the very same problem with my XJR....and a few other cars in the past. Very annoying. Worse in warm weather.
I'm not aware of a cure.
Old 07-01-2016, 03:18 PM
Rivguy's Avatar
I would second on the heater core leak. I had a a/c cooling unit suffer a sudden leak and it looked a smoke bomb had gone off inside. Once it was empty though it stopped. On a '97 the "outgassing" would have occurred during the first year or so.
Old 07-01-2016, 04:11 PM
Doug's Avatar
Hmmm, perhaps so.
But at 20 years old my XJR glass was constantly developing that oily film....and the heater didn't leak.
Not sure what else would account for it
Old 07-02-2016, 02:41 AM
GGG is online now
Received 16,747 Likes on 12,140 Posts
Do you treat the seats with Connolly Hide Food or a similar cream product?
As this dries off in a closed car it can leave a film on the inside of the glass.
Old 07-02-2016, 08:51 AM
Doug's Avatar
I used primarily Lexol and Aero 303.
In the back of my mind I was wondering if leather or vinyl conditioners might be causing the problem....which seems entirely plausible. If so, the effect lingers on for *weeks*. Clean glass, wait a week, clean glass again, repeat, repeat, repeat. Year after year after year
I suppose a person could not use any interior conditioners at all for a few months and see if the problem goes away.
Old 07-02-2016, 08:28 PM
Received 7,849 Likes on 4,749 Posts
ALL my jags since the 1972 XJ6 I bought in the mid seventies seem to leave a film on the inner glass surfaces. My wife notices it more than me!!!!!!!
Nature of the beast???
bob
Old 07-08-2016, 06:18 PM
al_roethlisberger's Avatar
This also happens on some of my older cars too. I have no idea why. The XJR seems OK so far.
FrankZ06
08-28-2016 07:05 PM
Bhpbug
05-03-2016 12:26 PM
Palmero
XJ40 ( XJ81 )
04-16-2016 08:24 AM
randyb
04-09-2016 02:07 PM
clivedavies
04-07-2016 10:21 PM
Quick Reply: Oily film inside windows???
