Differential noise
Old 01-13-2013, 12:40 AM
Brent's Avatar
Unhappy Differential noise
Hi to all you great guys on this forum, I need some help, my differential is making a whining/whirring sound. I have checked the wheel bearings and they are good, so jacked it up put it in gear and gave it some gas and the noise is definitely from diff.Faster I go the higher and louder the sound,and the reverse when I slow down. So my question is....is it the actual diff gears that are the problem or are there some bearings in the diff that can be the cause? There is no clunking when I put it in drive and or reverse.Any help would be really appreciated as I am in South Korea and the diff would be an extremely expensive part to purchase, so am hoping there are bearings that cause this.
Old 01-13-2013, 07:27 AM
mmeawad's Avatar
Coventry west sells an overhaul kit for the diff it includes bearings and seals
Old 01-13-2013, 08:21 AM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
Have you checked the fluid level and are there any signs of leakage?
Old 01-13-2013, 05:53 PM
Brent's Avatar
Default Diff noise
yes have recently changed oil and there were no leaks.The noise started before the oil change. Roughly the same amount of oil came out as the new oil put in, so it was not lack of oil that caused the problem.
What is the website address of Coventry West ?
Old 01-13-2013, 06:53 PM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
Land Rover Parts | Jaguar Parts | Coventry West, Inc.
The following 2 users liked this post by Doug:
al_roethlisberger (05-14-2018), Brent (01-13-2013)
Old 01-14-2013, 08:13 AM
Received 7,878 Likes on 4,762 Posts
Most likely the pinion bearing set needs to be replaced.
I never could find them at bearing suppliers so I always get them from the JAG dealer.
All the other bearings in the diff can be had at your local bearing supply house.
bob gauff
Old 01-14-2013, 04:44 PM
EZDriver's Avatar
OK Brent. Now that the best has responded and given you the best advice. Tell who the lady is.
Old 01-14-2013, 05:55 PM
basco1987's Avatar
I agree with Bob Gauff. I had the same problem in 2010 with my DD6.
You can replace the pinion bearings, but it's expensive and it takes an experienced and well versed mechanic.
Make sure the garage has the Vehicle Service Manual (esp. chapter 9); if not: you should find the fee-based download here: http://jaguartechinfo.com/ or pm me.
And last but not least: correct pre-load is of high importance.
Good Luck!
Old 01-14-2013, 06:44 PM
Brent's Avatar
OK the lady is my beautiful niece who is a model.
EZDriver (01-16-2013)
Old 01-15-2013, 02:51 AM
basco1987's Avatar
Jaguartechinfo:
Apparently the link doesn't work with the left mouse button. So try it with the RIGHT mouse button instead (open in new tab), this should work.
The address is: topix.jaguar.jlrext.com/topix/i18n/index
Brent (01-15-2013)
JimC64
31
05-30-2016 03:04 PM
inactualis
10-02-2015 11:13 AM
baskervillema
10-01-2015 06:43 PM
ChrisJay
09-27-2015 09:08 AM
Quick Reply: Differential noise
