Sovereign gearbox groan
Old 02-21-2017, 03:24 AM
damotron's Avatar
Default Sovereign gearbox groan
Hi all
I posted earlier about my gearbox whirring sound think I have explained wrong basically when you select drive Park or reverse or neutral it makes a loud hydraulic groaning sound coming from front of gearbox around bell housing area. All mounts are there as far as I'm aware.
It ​​​​​drives fine no slipping when gear changes but do hear a blip of a hydraulic groan when changes 1st to 2nd not as bad as when stationary selecting gear. So it's strange has anyone had this problem I was driving normally was a loud thud under floor well area did not run anything over checked dips tick no sign of metallic particles plenty of fresh fluid also. I my local garage thinks possibly torque converter and says sounds like a spline spinning not gripping but then again no shavings on dip tick. I really don't want to get new gearbox as I heard these should be bulletproof. It's a 1995 sovereign 4.0 aj16 x300
