Stuck in Park
Stuck in Park
Hey, My 1995 Jaguar XJ6 is stuck in park. Replaced starter and runs now but wont shift. I have red up some on it. Did take star out and did engage to drive, but still not shifting. No brake lights, no click noise of brake being depressed. Have not checked fuses. Not sure which to check and where. Any info or remedies. Thanks much
Welcome to the forum Kathy,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
If you're not hearing a click noise, that's the solenoid that locks the shifter in place till you press the brake pedal. You'll need to take the shifter trim ( wooden ski slope ) out of the way and the center console as well. It should a 2 way white connector. Would help to check fuses as well.
Received 10,747 Likes
Faulty brake light switch is likely.
The click come from the shift lock solenoid. The shift lock solenoid is operated by the brake light switch.
'Sometimes' jabbing the brake pedal very hard gives temporary relief.
Check this thread out......because jamming the brake pedal hard is temporary and its really not hard to fix except for having to be upside down for awhile ;-)
https://www.jaguarforums.com/forum/x...hanism-172126/
