Driver's side window - would like some help please
Old 12-27-2013, 08:30 AM
jrb53's Avatar
Question Driver's side window - would like some help please
2000 x308 vin# SAJDA14C6YLF03202
the problen I have is the drivers side window. it only works when it wants to ,have changed the window switch pack. I do not know if this is related to the fact my key fob only works when it wants to as well. when the window works it will go up and down with no resrictions any help would be greatfully accepted
Last edited by GGG; 12-28-2013 at 10:02 AM. Reason: edit thread title to add detail
Old 12-27-2013, 03:00 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
I cannot help with your problem, but you can probablly get better response with your problem in the subject line of your post- Most everybody here "would like some help".
Good luck with it , though.
Old 12-28-2013, 09:44 AM
jrb53's Avatar
Smile I should rephrase that
I should rephrase that. If any one has had the same problem it would help thanks
Old 12-28-2013, 10:05 AM
GGG is online now
Received 16,768 Likes on 12,155 Posts
I've edited your thread title to see if it will catch the attention of others who have had driver's window issues.
Intermittent faults are the worst. Troubleshooting a permanent fault is always so much easier!
jrb53 (12-29-2013)
Old 12-28-2013, 02:25 PM
mikebaker3's Avatar
Does your car have a sunroof? When you are having the driver door window problem, open the sunroof. Did I close by itself after a few seconds?
If so, what I am going to suggest sounds harebrained.
Disconnect the negative battery lead from the battery. Touch the lead (which only has the battery terminal clamp removed from the battery and is still attached to the car) to the positive battery post.
This is referred to as a "hard reset". It discharges the capacitors in the various control modules. Reconnect the negative battery cable. Did the problem go away?
When I had a problem with my driver's side window and was told to do this, I thought the poster was nuts, and yet it worked.
The following 3 users liked this post by mikebaker3:
Catenaccio (12-29-2013), jrb53 (12-29-2013), sparkenzap (12-30-2013)
Old 12-29-2013, 07:52 AM
jrb53's Avatar
thank you I will try that this morning. will post to let you know
Old 12-29-2013, 12:38 PM
jrb53's Avatar
Default hard reset
thank you for your help on this window problem, the hard reset worked.
Old 02-05-2014, 06:42 AM
Sirmicroby's Avatar
I have the same problem as well... My car is in the garage for the winter so I have problems simulating the intermittent problem.. I'm searching and testing and found nothing yet. Did the Hard Reset solve the problem for good or does it just restart the the window moving when it has stopped halfway?
Old 02-05-2014, 07:21 AM
Myxjvdp's Avatar
I'm also having a similar problem with my 2000 xj8 vdp, driver window stops working out of nowhere and sunroof opens but closes on it's own after a few seconds. I was told to re boot the memory by grounding the positive with the negative for a few second, after I do that it all works fine but then it'll go back to the same problem after a few hours or a day. Plzzzz help someone!
Sirmicroby (02-07-2014)
Old 02-06-2014, 07:02 PM
mikebaker3's Avatar
Default Why the Hard Reset was not a Permanent fix?
That I do not know.
My suggestion is to disconnect the battery, locate the module for the windows, disconnect the connector, spray contact cleaner into both the contacts on the plug and the pins on the module. Likewise, disconnect the window switches and clean those contacts as well.
All of the circuits in these cars that have control modules are sensitive to corrosion on the electrical contacts. The corrosion on electrical contacts increases the resistance which is what I think starts the problem.
I have not had a repeat of the problem on my car since doing the hard reset.
Perhaps someone that is computer savvy can explain why the hard reset works and why it does not seem to be a permanent solution on your cars.
The following 2 users liked this post by mikebaker3:
jrb53 (02-07-2014), Sirmicroby (02-07-2014)
Old 02-06-2014, 10:06 PM
Sirmicroby's Avatar
I planned on removing the door module to clean the contacts as you mentioned Mike. It is still another 6 weeks before I can ride again, winter and all...
A similar issue, the passenger seat back at times goes only so far back up then starts clicking. The forum gave me the tip to clean the contact of the seat module under the seat which I did. This had solved the problem but I have to redo this procedure every year. I will keep in touch with this side window issue... Thanks for the reply,,,
Old 02-07-2014, 08:26 AM
jrb53's Avatar
thanks mikebaker3 I will try this it makes sense. thanks to all, will post later.
Old 02-07-2014, 09:08 AM
Cabezagrande's Avatar
I had the same problem, every window working but the drivers side front, and a hard reset worked for me.
Old 02-07-2014, 11:59 AM
Myxjvdp's Avatar
Thanks a lot mike, I will be trying your procedure this after noon if it's not too cold outside. Thanks I hope it all starts working
Old 02-07-2014, 12:49 PM
L80ous's Avatar
Just had this problem as well, hard reset baby yeah baby!!
Old 02-22-2014, 02:15 PM
Myxjvdp's Avatar
Ok, I finally figured out what was cousing this proem on my car and would like to share it with y'all. So I found out that the key hole on my door was getting stuck and it remained on global closing. So I decided to spray wd40 in the key hole and insert the key and unlock and lock a few times. After I deleted this a few times I notice when I would turn the key it was a lot smother and would spring back to the center right after turning the key. So after that procedure was done I did the hard reset one more time and it's been working perfect since then, and it's been a few weeks now so it would usually last a few hours before it started malfunctioning again. I'm so glad I solved this issue, I hope this helps someone out there.
Sirmicroby (02-23-2014)
99xk8guy
06-05-2023 06:28 AM
kevinl
10-31-2019 06:15 PM
sadepol01
09-11-2015 05:26 AM
tberg
09-07-2015 07:32 AM
Dallas XK8
09-03-2015 12:17 PM
Quick Reply: Driver's side window - would like some help please
