Fuse box layout diagram - Jaguar Forums - Jaguar Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 10-01-2009, 03:04 PM
Default Fuse box layout diagram
I'm wondering if someone could snap a quick picture of their fuse box diagram on an xj8. Mine is missing and I have no idea which fuse/relay is which. I tried searching but couldn't find one.
Thanks in advance!
Old 10-01-2009, 08:05 PM
there are no less than 4-5 fuse boxes/panels, maybe more. Which one are you looking for, or what are you looking to replace.
Old 10-01-2009, 08:29 PM
I'm looking for the diagram for the fuse box next to the battery in a 99 XJ8.
Old 10-01-2009, 11:29 PM
Sarc's Avatar
Isn't there a sticker inside the lid of the fuse box telling you the fuses ? (I can't remember and I'm too lazy to go down into the garage to check)
Old 10-02-2009, 10:20 AM
not on my lid. No location diagram, no list, no nothing, haha! If someone has the diagram i'll print one out and stick it in there.
Old 10-02-2009, 01:58 PM
SuperSport's Avatar
Pages 4-12 through 4-24
This attached Document was downloaded freely from the Jaguar Website. It is for the 2000 XJ's, but I've yet to find a difference in my 1999 XJR.
It shows the Fuse/Relay Locations, and usages.
If you don't already have it installed, you will need the Free Adobe Reader to open the Document:
File Type: pdf Jaguar_XJ_2000_Vehicle_Care_Handbook.pdf (1.35 MB, 6223 views)
The Following 2 Users Say Thank You to SuperSport For This Useful Post:
JagBenny (10-02-2016), Rsv004 (10-23-2014)
Old 10-02-2009, 04:45 PM
Thanks! that does list all of the relays and fuses but not which number is which in the box itself. Is that cast into the box per chance? I couldn't see any numbers but maybe I wasn't looking close enough.
Old 10-02-2009, 05:57 PM
Sarc's Avatar
I think you can see the numbers on the fuseholder bodies.... I'll check when I go home tonight
Old 10-11-2009, 01:55 AM
lassiedog1
Guest
Posts: n/a
been trying 4 an age to get relay possition plan many thanks stan
Old 10-11-2009, 06:38 AM
hughey's Avatar
I have this booklet and have looked to see if there is any fuse or relay that controls all of the steering column controls, but haven't found anything. I have no function from any of the controls on the steering column except for the turn signal and wiper stalks. Everything related to those functions properly, but all other controls (column adjuster, cruise control, radio controls, horn) are dead. Any suggestions?
Old 11-11-2009, 12:11 PM
emanuelecruciani
Guest
Posts: n/a
Default jaguar xjs v12 convertible
Hi , I'm Emanuele and I'm looking for some one that has a vehicle hand book for the xjs v12 convertible. I have a trouble with the top roof. I really need to know where all fuse boxes are.
Old 08-05-2010, 10:56 AM
I tried to download the handbook but it will not let me. Could you please send it to me at brhassell@gmail.com as I would appreciate it.
Old 08-05-2010, 11:00 AM
Default Need handbook.
I tried to down it but it would not let me. Please send to brhassell@gmail.com
Old 08-05-2010, 11:09 AM
SuperSport's Avatar
Quote:
It's been sent. Let me know if you have any problems opening it.
Good Luck!
Old 10-10-2010, 12:41 PM
Anybody have Instructions on how to remove the Exhaust from 2001 XJ8. Seems to be the only way for me to get to the O2 Sensors
Old 06-26-2011, 06:10 AM
Id like to have a fuse layout for my 1999 XJ8- Im trying to find the fuses for the engine fans- any help would be appreciated. I cant open the booklet- dallasisland@netzero.com Thanks!
Old 07-01-2011, 06:40 PM
Default 06 X-Type Owners Manual
It say's I don't have access to this info?
Old 07-02-2011, 04:43 AM
Cadillac's Avatar
Quote:
Because you're totally a new member you need min 10 posts and a few days , please re read your pm it explains you why
Old 07-02-2011, 10:50 AM
Hi dac44444
I put a 2006 X-Type Owners Manual PDF I created in a new thread in the X-Type section of the forum:
http://www.jaguarforums.com/forum/x-...47/#post372395
Jim Lombardi
Old 09-06-2011, 02:08 PM
Default 2000 xj8 brakes
Ok folks I have a 2000 xj8 and the barke lights stay on all the time. I replaced on burnt bulb and it did not fix the problem. I also unplugged the switch at the brake pedal and they went off. I am guessing that my switch is bad. Anybody had this problem?
Thread Thread Starter Forum Replies Last Post
Can't get it out of Park hamilton7550 XJ XJ8 / XJR ( X308 ) 20 10-19-2015 09:31 PM
2000 S Type 4.0 - Overheated Today No Fan then Fan Started Working?? abonano S-Type / S type R Supercharged V8 ( X200 ) 25 09-25-2015 11:43 AM
2011 Jaguar XF Premium wiring issues drewlabarbera XF and XFR ( X250 ) 1 09-22-2015 02:54 AM
Help fuse box confusion X-Type 2001 r111ynf X-Type ( X400 ) 11 09-20-2015 10:42 AM
85 XJ6 Blower Motor question eurotire XJ6 & XJ12 Series I, II & III 17 09-18-2015 08:27 AM
Tags
2000, 2006, box, diagram, escort, fuse, fusebox, jaguar, king, layout, location, panel, relay, road, series, type, xj
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
