Gearbox not changing gear.
Old 06-21-2017, 03:54 PM
Marvelbiz's Avatar
Default Gearbox not changing gear.
Year 2000 xj8 auto. Not changing gear. Message says gearbox fault and high temperature
Old 06-21-2017, 05:02 PM
Kejar7's Avatar
The first thing that I would do is check the fluid level of your transmission.
It is a PITA but this is the first step to a diagnosis.
Has it been changed recently?
RAM
Old 06-21-2017, 05:29 PM
Received 7,862 Likes on 4,752 Posts
Is the gearbox temp ACTUALLY HIGH???
If not then the thermistor integral with the internal harness is faulty.
You will need to replace the gearbox internal harness as the temp sensor is Not Sold/Serviced Separately. (NSS)
bob
iwillfixit
06-19-2017 01:55 PM
FloridaPilot
06-04-2017 06:23 PM
Kejar7
05-29-2017 10:03 PM
Sceleton
05-29-2017 10:23 AM
schnikies
05-27-2017 10:00 AM
Quick Reply: Gearbox not changing gear.
