Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ40
Sign in using an external account
Register Forgot Password?
Search
XJ40 1986 - 1994
LinkBack Thread Tools Search this Thread
Old 08-19-2012, 08:30 PM
Default 1993 XJ6 "Anti-Lock" and "Brake" light on, and brake hard
Hello, I have a 1993 XJ6, Lately a lot of problems had arise, I fix one thing something else fails.
recently changed spark plug and cap and rotor, that failed.
power steering hoes was replaced, and when driving the brake lights came on both anti lock and brake light on bottom.
Could any one give me some suggestions what I can do? to fix this brake problem.
Right now i am planning on buying the brake sensors, for only fronts? or all 4 front and rear?
if that doesnt fix it, what else could it be?
Thanks any info would happily appreciated. the car runs strong, need to fix this and get my A/C working to be more complete.
Old 08-20-2012, 08:33 AM
MidwestJag's Avatar
Untitled
Hi:
Welcome to the forum. Please take a moment to introduce yourself in the 'new members' section. We like to stay really friendly around here!
My gut reaction was a failing accumulator sphere. To check, turn key to position II (without starting) and allow the pump to run until the ABS and Brake lights are extinguished. With ignition still on, pump the pedal two times and the pump will again recharge the sphere. Then turn the car off, and you should have a good 25-30 pumps of the pedal before it goes hard. If it goes hard right away - bingo; Very likely a sphere not holding pressure.
Again welcome!
Scott
__________________
Scott (Wisconsin, US)
'91 & '94 XJ40's
Take a moment to check in with other forum members in the Midwest!
http://www.jaguarforums.com/forum/mi...n-mo-oh-wi-39/
Old 08-20-2012, 11:32 AM
alright, the ABS and Brake lights does not extinguish? reset the battery and same thing. The brake pedals are still stiff.
So the only thing need replaced is the accumulator sphere itself, a sphere thats attached to the accumulator? from between which particular year can i buy this if used?
Old 08-20-2012, 09:07 PM
If the Brake and Anti-Lock lights do not go out and the brake pressure is always hard the electric pump may be not operating. Check to see if the booster motor is operating and check the fuse feeding it to see if it is blown.
__________________
Mountain Pilot
1990 XJ40 Sovereign and other toys..
Monte Vista, Colorado, USA
Old 08-26-2012, 07:58 AM
I just wanted to say that replacing the accumulator had fix the problem, I bought the part used online, I actually replaced the whole thing, not just the ball but the accumulator itself. easy, took 5 minutes.
I now would like to get the A/C to work, I'll start a seperate thread.
Thanks everyone who had chimmed in.
Tags
1993, 93, accumulator, anti, antilock, brake, hard, jaguar, light, lock, panel, pedal, problem, sphere, xj40, xj6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
