Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Classics ) > XJ40
Sign in using an external account
Register Forgot Password?
Search
XJ40 1986 - 1994
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 08-12-2011, 06:13 PM
Default 94 XJ6 wiper problem
The windshield wipers turn on but stop after moving sometimes half way across the windshield sometimes less, the motor is running just no movement on the wiper blade, any suggestions. Thanks
Old 08-12-2011, 07:05 PM
It could just be a worn spline where the wiper arm attaches to the motor...check to see if it is loose and tighten it up or take it off, add a little silicone or something similar, reattach and see it that cures the partial movement
Old 08-12-2011, 07:42 PM
Thanks i'll give it a try
Old 08-16-2011, 05:20 AM
mrtalkradio's Avatar
Do you mean that when you use the intermittent setting it won't do a complete swipe?
__________________
1992 5.3 XJS Diamond Blue
1992 Mercedes 400SE
The Following User Says Thank You to mrtalkradio For This Useful Post:
petek57 (08-20-2011)
Old 08-20-2011, 12:06 PM
mrtalkradio yep it wont complete the cycle. the wipers intermittely work in the other speeds. If you take the wiper off the windshield it works. if you use the intermittent cycle it screws the wiper sequence up completely. any suggestions would help. thanks
__________________
1994 XJ6 sedan
Old 08-20-2011, 06:24 PM
checked as much as i can without removing complete assembly, everything seems to be attached, as long as the wiper blade is off the windshield it works as advertised, once you put the blade back on the windshield it wont complete any cycle, help lol
__________________
1994 XJ6 sedan
Old 08-20-2011, 08:28 PM
I had the same problem on my 90,what happened was in the winter the wipers were turned on with a lot of wet snow on the windshield and stopped half way. After cleaning the windshield of snow an starting the wipers they would not complete a full cycle when in the intermitent mode,but worked fine a full speed. Replaced with a used wiper motor which i bougt from a salvage yard and it worked as it ahould.
The Following User Says Thank You to Lumppy47 For This Useful Post:
petek57 (08-27-2011)
Old 08-27-2011, 05:08 PM
Where is the wiper motor relay located on a 94 XJ6, thanks
__________________
1994 XJ6 sedan
The Following User Says Thank You to petek57 For This Useful Post:
jaglawer (01-16-2012)
Old 08-31-2011, 12:23 PM
In regards to the problem that I had asked about, the issue is a fuse under the passenger side kickplate. You will see it just hanging there. 99.9% sure if you change that fuse the intermittent wiper action will complete its full sweep. Do a search in the forum, as i had to do on both my 90's. There is even a picture on here somewhere of the exact location and what it looks like. It fixed both my cars problem with that intermittent setting. Hope that helps.
__________________
1992 Mercedes 400SE
petek57 (09-03-2011)
Old 09-27-2011, 01:03 PM
Default wiper motor problems
Replaced the motor works great but the blade parks in the drivers view and not at the bottom of the windshield. anyway to adjust where the blade parks thanks
__________________
1994 XJ6 sedan
Old 09-27-2011, 08:03 PM
They all park on the drivers side. You'll get used to it. You didn't need to change that fuse?
__________________
1992 Mercedes 400SE
Old 09-28-2011, 05:29 PM
Default xj6 wiper problem
well i repaced the wiper motor and it works great except when it parks its in the middle the driver windshield, i do believe is should be a little lower toward the bottom of the windshield any suggestions. thanks
__________________
1994 XJ6 sedan
Old 09-29-2011, 08:03 AM
Did you replace that fuse?
__________________
1992 Mercedes 400SE
Old 10-01-2011, 09:21 AM
i've looked for the fuse on the passenger side, cant locate it, looked behind the kick panel, no fuse insight, any suggestions
__________________
1994 XJ6 sedan
Old 10-29-2011, 05:56 AM
Did your issue get resolved?
__________________
1992 Mercedes 400SE
petek57 (05-26-2012)
Old 11-24-2011, 09:44 PM
Default windshield wiper motor
Quote:
have not been able to locate the fuse behind the passenger kick panel, it might be different on the 94 model. wipers work they just dont park in the proper location when stopped
__________________
1994 XJ6 sedan
Old 12-21-2011, 01:41 PM
Default Inline Wiper Park Fuse 89-94
Quote:
I know you fixed your issue, but here is where that fuse is. And for anyone whose wiper's don't park while being in intermittent mode.
__________________
1992 Mercedes 400SE
Yari (02-23-2013)
Old 01-05-2012, 11:32 PM
sleepycat's Avatar
Lightbulb Maybe this will help...
I know this question was asked a while ago and the problem may be fixed but others may be experiencing the same thing.
It may be the fuse as mentioned if it is happening in int mode, it is a 10 a if I recall and is located in the right foot well behind the knee bolster sort of inline not in a block it is a blade type fuse (ATO). Change that if the problem happens during intermittent mode.
If as stated there was heavy snow or the arm was frozen in place it may have slipped on the splines and just need to be removed and properly placed, just remove the hold down nut, pull off the arm and replace in the proper park position.
Or... maybe the park switch is cracked, it is located under the top cover of the wiper trans box, remove the cover and run the wipers and see where the cam is contacting the switch when the wipers are turned off. You may need to remove it and and position it where it contacts the switch later. It may be cracked or loose on the shaft, you can try gluing it that may work.
Please use extreme care when working around the wiper mechanism, it has alot of torque and can really hurt you.
Hope this helps.
__________________
1991 VP Black 4.0
What Now ???!!!
The Following 4 Users Say Thank You to sleepycat For This Useful Post:
Cadillac (01-06-2012), CosmosXj6 (02-24-2013), pipedreamer (10-07-2013), Yari (02-23-2013)
Old 01-27-2013, 05:14 PM
Good exchange, but still don't know where the location of the wiper motor fuse is, or where the switches are for this motor. Still looking.
Old 01-28-2013, 01:41 PM
Quote:
This picture doesn't help? That is the location of your wiper motor fuse. The microswitch that is spoken about in an above post is under the cover of the wiper motor, under the hood.
__________________
1992 Mercedes 400SE
Tags
1990, 1992, 1994, 91, forum, jaguar, location, motor, problems, relay, removal, starting, washer, windshield, wiper, work, xj6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
