Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ40
Sign in using an external account
Register Forgot Password?
XJ40 1986 - 1994
LinkBack Thread Tools
Old 09-15-2005, 01:44 AM
Guest
Posts: n/a
Default Ac unit repair on XJ40
My AC blower motor is not working right and left. I don't get any power into control unit and radio. I replace compressor, ac cutoff switch. I check control unit is ok, AC ECU is ok, compressor will kick in if you over ride relay. But no power at control unit or radio, so no blower motor operates. Do you no where main power source come into control pannel and ECU to radio?
Old 09-20-2005, 04:58 PM
Patrick's Avatar
Administrator
Default RE: Ac unit repair on XJ40
have you checked the fuses for that section of the car?
Old 11-29-2005, 11:20 PM
Guest
Posts: n/a
THE FUSE BOXES LIKED GETING WET AND SOGGEY ON THESE MODELS
Old 12-17-2005, 12:48 PM
Guest
Posts: n/a
I checked fuses they are fine. I also checked relay. I do think ground on relay which is relay for a/c and radio. I can over ride this relay and units come on. I don't have any idea where this ground goes too.
Old 01-15-2006, 02:46 PM
Guest
Posts: n/a
ITS A SWITHCED GROUND FROM YOUR ACCM IF LIKE YOU SAY THIS IS GOOD YOU PROBABLY HAVE A BROKEN WIRE.
Tags
ac, accm, blower, blowers, fuses, jaguar, module, motor, override, relay, repair, replace, type, unit, xj40
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Advertising Information - Contact Us - Jaguar Forums - Jaguar Enthusiasts Forum - Archive - Top
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
