XJ40 ( XJ81 ) 1986 - 1994
Inside the Heater Blower
Old 11-08-2013, 10:22 PM
andyrupert-com's Avatar
Default Inside the Heater Blower
My son and I took apart a non-working heater blower motor to see about repairing it. If you have never opened one up, you may find this to be interesting.
1990 Jaguar Sovereign : Disassemble the Heater Blower | AndyRupert.com
MidwestJag (11-09-2013)
Old 11-09-2013, 01:48 AM
Lawrence's Avatar
Received 1,854 Likes on 1,180 Posts
Just watched your dis-assembly video Andy - the relays inside the housing are not actually all that standard - these blue Hella relays have internal diodes. There's a few good threads on the forum about modifying radio-shack relays using a diode soldered on the outside - that's what I did on mine.
If you're going to completely rebuild the blower you should also take a look at the speed control transistor circuitry, it's accessible by drilling out the three pop-rivets. If a fan only blows on high it's usually because the speed control circuit has a problem. One of the relays is used for high speed fan and by-passes the speed controller.
I replaced the darlington transistor and all the other components on the speed control circuit board when I replaced the relays.
Check out the threads on the blower repairs, there are quite a few detailed postings.
MrWhite
19
06-14-2022 07:49 PM
xjrjag
10-12-2015 03:16 PM
sg997tt
10-09-2015 10:57 PM
Markus
09-28-2015 01:55 PM
Quick Reply: Inside the Heater Blower
