XJ40 ( XJ81 ) 1986 - 1994
What Battery to fix a 94 4.0 Daimler
Old 02-08-2012, 12:52 PM
ianhearse's Avatar
Default What Battery to fix a 94 4.0 Daimler
I need a new battery for my 1994 Daimler XJ40 Hearse.
Unfortunately when my local motor factor tries to search for it by the registration number it just comes up as a hearse so they are struggling to get the correct battery number.
Does anyone know the correct battery type an XJ40 4.0 should have fitted.
Thanks in advance
Old 02-08-2012, 05:24 PM
Received 7,879 Likes on 4,763 Posts
The GROUP 47 is what is listed as correct but I don't know if that is a universal designation or an old North American number.
bob gauff
Old 02-08-2012, 07:18 PM
GGG is offline
Received 16,799 Likes on 12,168 Posts
An XJ40 hearse - that must be quite some car.
The GROUP 47 designation Bob has quoted may not be recognised in the UK. The Jaguar Part Number when I last bought one for an XJ40 in 1999 was:
LNC1250AA
It was a VARTA battery and Jaguar still use this manufacturer.
The important consideration is rating and dimensions. The original battery Jaguar fitted to the standard XJ40 was 72 amp/hr although such a specialised and heavy conversion as yours may have had one of a higher rating. If you want to avoid the Jaguar Dealer, go for a battery of at least this rating with the same dimensions and terminal post layout as the one on the car. Apart from Varta - Bosch and AC Delco will certainly have one suitable in their ranges.
Old 02-08-2012, 09:41 PM
Here is some info for the North American market. I don't know if it will translate to Europe.
bob gauff
Cadillac (02-09-2012)
Old 02-09-2012, 05:16 AM
Cadillac's Avatar
I do use VARTA too , 12 V 72 AMP as I recall
Old 02-10-2012, 05:19 PM
db in uk's Avatar
Thanks in advance
LNC1250AA is still available from Jaguar but is quite expensive at £106+VAT.
Genuine Jaguar Parts and Jaguar Accessories for Classic Jaguars
GGG is correct - is a VARTA battery, rated at 72 amp/hr. You will be able to get the same battery quite a bit cheaper elsewhere.
JarodL
03-07-2024 01:39 AM
99xk8guy
09-21-2019 07:34 PM
vicom
09-17-2015 03:32 AM
jaguarbill
09-05-2015 11:43 AM
Harry Dredge
09-05-2015 02:44 AM
Quick Reply: What Battery to fix a 94 4.0 Daimler
