XJ40 ( XJ81 ) 1986 - 1994
My cat has lost her mind!!!...
Old 06-29-2012, 10:30 PM
sleepycat's Avatar
Question My cat has lost her mind!!!...
Just when I thought I was getting close to being able to truly
enjoy a trouble free Jag, she went nuts.
New Battery
New Coil
New Plugs, Cap, Rotor Wires
New EGR
New FPR
New CTS
New Thermostat (88C)
New O2 Sensor (exact fit)
TPS tested, cleaned and set to specs
Rotary Switch cleaned and tested ok
New Relays under pass side bolster
Checked grounds cleaned and tightened
This is most of what has been done to her to get her running pretty
good til the other day then bad idle, rich running, stalling, loss
of power, then the limp mode and cel returned with a vengeance,
FF69,67,57,12,11,37,35,27,29,23,19,38,35,56,25,45, ???
Some of these codes seem to be mysteries as I can't find any info
on them.
Could this be a CPU error?
Clearing the codes manually, they all return on the next restart.
With the center console fuse removed tranny lite goes out til next
restart.
Pulling -tive terminal on battery for any amount of time clears
codes til next restart.
I think this jag is headed for the crusher, any ideas before I turn
her into a pancake?
Help
Charlie
H20boy
07-23-2021 09:39 PM
Thang Nguyen
10-12-2015 01:25 AM
Lannyl81
09-20-2015 08:56 PM
Johnken
09-15-2015 05:46 PM
1100me
09-07-2015 06:26 AM
Quick Reply: My cat has lost her mind!!!...
