XJ40 ( XJ81 ) 1986 - 1994
1990 XJ6 mass air flow aftermarket pinout
Old 05-04-2016, 01:19 PM
integra22t's Avatar
Default 1990 XJ6 mass air flow aftermarket pinout
i had to order a mass airflow off ebay ( Python Injection 825-744 ) and it comes in a 3 pin conector
the stock mass airflow is a 6 pin conector
i know one of the pins is a ground and there is a 2 wires are grounds for the sensor so that leaves the power/signal/ and idle trim
the problem is i dont know what the pin out is for the Python mass airflow so i dont know what goes where ... i tryed to use a ohm meter to probe the sensor but it was no help
anyone here ran into this as the company has gone under
thanks
Old 05-04-2016, 01:46 PM
GGG is online now
Received 16,747 Likes on 12,140 Posts
Welcome to the forum integra22t,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old 05-04-2016, 03:17 PM
Lawrence's Avatar
Received 1,853 Likes on 1,179 Posts
Xk's Unlimited sell 'em - why not give them a call?
JA-DBC12516/E - Airflow Meter Three-Pin. $75 Core Charge
Larry
Old 05-04-2016, 03:36 PM
integra22t's Avatar
thanks sent them an email ... still looking for the pin out
thanks
Old 05-04-2016, 09:41 PM
Received 12,696 Likes on 6,364 Posts
Hi integra22t,
Welcome to the Jaguar Forums. It's great to have you with us.
I just reviewed the schematic for the 1990 XJ40 and the stock MAF sensor has six pins. The Black wire of the harness connects to ground at the intake manifold stud at cylinder 2. The two Black wires with Yellow tracer lines tie together and connect to the ECM. The White/Brown, Green/Red and Green/Pink wires also connect to the ECM, for a total of four connections to the ECM plus a ground. Unless you know something you haven't told us, it doesn't appear that the Python MAF is suitable for use in an XJ40. You can download the 1990 Electrical Guide here:
http://www.jagrepair.com/images/Elec...Electrical.pdf
When you get a chance, please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction so we can learn something about you and your Jag and give you a proper welcome.
Cheers,
Don
93SB (05-15-2016)
Old 05-05-2016, 08:58 AM
integra22t's Avatar
im taking it that the 3 pins on the new one are power/signal/ and idle trim
as for the 1 wire ground isnt a problem .. the other 2 sensor grounds i was hopeing just to add to the 1 wire ground
ive ran into this sensor a couple of times and it says it fits the xj6
im a Honda guy that builds and wires performance cars at Autofunctions Speed-Custom ... i got the sensor for a friend as we couldnt find a supplyer through our local jobbers
if i can find a car that uses this sensor i should beable to wire it up but dont want to take the chance it will pop his ecu
maybe what i should be asking is what car uses the Python Injection 825-744 mass airflow and try to work from there wire diagrams
p.s this is a great site for info ... sorry im just not a Jag owner .. just hopeing to solve a problem incase anyone else runs into it
Old 05-05-2016, 09:18 AM
integra22t's Avatar
after some serching i found this thread https://www.jaguarforums.com/forum/x...uestion-58622/
that talks about a 3 wire maf sensor on a 1996 xj6 ... anyone have the engine wire diagram for it ?
Old 05-05-2016, 09:22 AM
Hi integra22t,
Since the XJ6 was manufactured from 1968 to 1997, saying a part "Fits the XJ6" is like saying it "Fits a Mustang." I don't remember that the EMS for the earlier Series III XJ6 cars used a MAF, but it might be worth asking your questions at that forum. You could also ask at the forum for the factory code X300 XJ6 (1995-1997), since those cars used a completely different EMS made by Lucas-Sagem-GEMS that might use a 3-wire MAFS.
Cheers,
Don
93SB (05-15-2016)
Old 05-05-2016, 10:11 AM
Lawrence's Avatar
For the sake of a few bucks why not get a MAF that fits the car, like a 3AM or a later model like the 5AM (which works fine on the OEM 3AM supplied cars) - I don't know anyone who runs a 3-wire MAF on an XJ40 flavour of the XJ6!
The parts place that sold this for the XJ40 is out to lunch.
here's one for you, pretty good deal too ..
1992 1996 Jaguar XJ6 XJS Mass Air Flow Sensor Meter MAF Mafs 5AM DBC 12516 | eBay
This one will fit!
Larry
Don B (05-06-2016)
Old 05-05-2016, 12:09 PM
integra22t's Avatar
thanks ... im 500 deep into this sensor now with buying, shipping, and duty so i would like to see if i can get it to work .. i would perfer not to buy a used one as he would like a new one
it just sucks that the seller said it would work
thanks for all the info
Old 05-06-2016, 01:23 AM
Lawrence's Avatar
Even though the meter you have is listed as a DBC12516E, it doesn't look anything like one!
It is, however, it is a close match to a LHE1620AA, a 3 wire type fitted to some later cars (post XJ40 AJ6 engines) like the 1995 and 1996 X300's (the x300 is also an XJ6 but with different motor/ignition/ECU as Don mentioned earlier) XJ8's, and SOME late XJS's and apparently some other models. [I'd double check on that too btw!]
You *may* be able to mcgyver the car to run with this meter but you'd also have to modify the harness/plug assy? I guess you have your reasons to persevere (500 of them you say!) ...personally I'd just abandon going further down this road and get the right part, even if it's a used one - but if you do manage it, please let us know how the car runs afterwards, i.e gas mileage etc
good luck
Larry
Old 05-10-2016, 03:09 PM
integra22t's Avatar
thanks for all the help guys ... after i got a pin out from a 1996 X300 i was able to conferm that the new mass airflow dosent have the idle curcut ... so i figured i could fool it by taping into the tps for the idle curcut but it wants 1.2v at idle and increase to 5v
just incase anyone wants to play with something like this in the future here is the pin out
----> front of car
old sensor
36,6,7,8,9,12
black,brown,green,empty,white,green
ground,ground,ecu sensor swiched ground,empty,12v,signal
new sensor
1,2,3
black,green,brown
12v,signal,ecu swiched ground
im calling it a day ... i hate being the middle man on this .. now i have to try to get my money back
ANYONE LOOKING FOR A MASS AIRFLOW # Python Injection 825-744
MechEng
E type ( XK-E )
04-28-2016 06:57 AM
richard1159
04-16-2016 07:54 AM
revski666
04-12-2016 07:03 AM
HarvesterUT
04-08-2016 06:36 PM
revski666
04-05-2016 02:24 AM
Quick Reply: 1990 XJ6 mass air flow aftermarket pinout
