Trunk/Boot reeks of exhaust fumes...
After driving the car when I open the trunk it reeks of exhaust fumes, also when I open the windows the interior of the car fills with the same odor. So much so that my clothes smell, people ask me if I was smoking,lol. No odor with the windows closed. It is exhaust fumes not gasoline fumes, just so that is clear. I don't detect any exhaust leaks in the system, I read somewhere that cabin/trunk exhaust odor was a problem in some of these cars. Anyone have an idea/solution? Would really appreciate it.
Thanks,
Charlie
Thanks,
Charlie
Two problems one leaking or rusted exhaust system,two body rot,or body plugs where wires pass into the cabin somewhere near the leaking exhaust. Why you dont get the fumes when the windows are closed is that there is no suction sucking the fumes into the cabin.When you open the window it creates a suction and the fumes come in. Also even if you dont smell the fumes you most likely are still getting some carbon monoxide into the car.Fix it asap remember dead is a long time.
Odor from boot
Charlie,
I have attached a service bulletin regarding the ingress of fumes from the exterior. Keep in mind, this particular bulletin was written for 88/89 MY, but it should give you a good idea on where to start looking and maybe some things that a person may overlook.
Good luck
Rob Evenson
Good luck
Rob Evenson
Thanks,
Charlie
Thanks,
Charlie
Odor from boot
For some reason the forum wouln'd let me upload the file, so I'll try later today or tomorrow, sorry
Charlie,
Good luck
Rob Evenson
Good luck
Rob Evenson
Check the size of the file you're trying to upload.
The usual reason for problems is where an attachment exceeds the permitted limit (e.g. a DOC is 2.1mB and a PDF is 9.54mB limit).
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
10-02-2015 12:13 AM
baskervillema
10-01-2015 06:43 PM
