XJ40 ( XJ81 ) 1986 - 1994
How much mineral oil?
Old 01-28-2011, 08:33 PM
cocco78's Avatar
Default How much mineral oil?
How much mineral oil do I need for the power steering? It looks to be empty and I for sure don't have any power steering. I believe I have found the source of the leaks and now I just need to make sure to order enough oil to fill it up and I guess have a little extra because i'm sure it will still leak a bit
Old 01-29-2011, 08:21 PM
Lumppy47's Avatar
get enough to fill the ressevour,usually two or three bottles of castrol. you might want to stop the leakage before adding fluid.(check all hose fittings and where they go into the steering rack,usually the o rings at the fitings are bad)
Old 01-30-2011, 09:03 AM
cocco78's Avatar
I believe I fixed the most apparent leaks, yes simple O rings...
Probably 3 of these?
http://www.motorcarsltd.com/jlm9886.html
MrWhite
19
06-14-2022 07:49 PM
Dave1109971
12-15-2015 06:16 PM
3jagfamily
10-01-2015 01:49 AM
Woznaldo
09-26-2015 11:02 AM
ahunt4
09-25-2015 03:43 AM
Quick Reply: How much mineral oil?
