Gas tank switch not staying pushed in..
Old 05-29-2011, 08:52 PM
Limey's Avatar
Default Gas tank switch not staying pushed in..
..Hi guys,
XJ6 '84 here, this AM I went to push the button to switch fuel tanks, and the button wouldn't stay in. If I hold it, it will draw fuel from that tank, but when I let it go, it returned to the other (now empty) tank.
Thoughts?
Old 05-29-2011, 09:53 PM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
Buy a new switch or disassemble the old and try to fix it. I think you'll end up buying a new one.
Old 06-02-2011, 02:58 PM
sneal46's Avatar
I may have an extra one of these laying around from a parts car I fleeced.
Limey (06-05-2011)
Old 06-05-2011, 09:46 PM
Limey's Avatar
Default Golly, thanks!
I appreciate the offer..I ordered one from Rock already. If it doesn't work or look right, then I might take you up on your kind offer!
thanks!
Sam
Old 06-06-2011, 10:54 AM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
These switches were one of the main issues with the Series 3 when the new (privatised), Jaguar management under John Egan took over from British Leyland. They are easily dismantled for fettling, but you could put a new one in if you can find one, as the internals are a bit Micky-Mouse.
Old 06-07-2011, 10:24 AM
Limey's Avatar
Default Rock auto has them for $20...
..so replacement is at least cheap. Does the button itself just pull out of the dash for replacement, or do I have to get it from behind?
Old 06-08-2011, 06:46 AM
As I recall, it is pushed-in to fit it, as there are molded-in clips that snap onto the rear of the housing. You have to be careful and may have to push these in whilst pulling on it to remove - suggest something in plastic not metal. A plug/socket connects the wiring.
Razor
08-28-2019 08:34 PM
GordoCatCar
01-02-2017 01:10 PM
hen555
09-07-2015 11:13 PM
alpecsa
09-07-2015 11:55 AM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
Quick Reply: Gas tank switch not staying pushed in..
