1996 xj6 4.0
1996 xj6 4.0
Hi. I'm new to jaguars and I have recently had a problem with my 96 xj6 with a 4.0 In it. When I start it it turns over till about the end than starts. Everything is fine once it starts. But it takes a second or two to start. Longer than it used to. I was wondering if anyone would know what it is. And what part number I need and where I can get it cheapest. I appreciate any and all feedback. Thank you very much.
It could be a lot of things. So you'll need to be more specific. Does it happen on every start or only when it's cold? How cold is it where the car spends it's nights? When was it last serviced? What kind of mileage has it done? & any other info you might think relevant will be useful too
Firstly, welcome to teh Forum.
When time permits, please do an Intro in the New Members Area.
Your 1996 XJ6 is known as an X300, and waaaaaaay more modern than the beasts in here.
I suggest a repost in that Tech Section will get the answers.
Mileage travelled will be very helpful.
My experience with them at this age is the Crank Angle Sensor, followed by the fuel pump.
Received 2,399 Likes
Doug (02-17-2017)
I agree with Grant. You'll get a lot more detailed info from the guys on the XJ40 forum. Our cars may look the similar. But that's as far as the similarities go. Your's is a much more modern machine, crammed full of microprocessors that ours don't have. OK, ours have chips too, but not nearly as many as your car has. & I wouldn't be surprised if that's where your problem lies. So maybe a trip to a good Auto Electrician could solve your problem
Received 10,757 Likes
I agree that the crank sensor is a good candidate.
Also agree that a an additional one or two seconds cranking time isn't much to go on. It might be hard definitively identifying a concrete fault when the symptom is so minor. I can see some guesswork in your future if you pursue the issue.
Grant Francis (02-17-2017)
