Wiring Question
Old 08-07-2011, 03:04 PM
solerunner's Avatar
Default Wiring Question
Just took my dash apart on my 1983 XJ6 to replace it with a newer one. When trying to put it back together, I can't remember where the two wires in the attached pictures go. Can someone please advise? Thanks!
Old 08-07-2011, 03:07 PM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
A little hard to tell but those might be fibre optic cables that snap into sickets behind the ignition switch and headlight switch
Old 08-07-2011, 03:24 PM
solerunner's Avatar
Thanks Doug. I attached a better picture (hopefully). As you can see, the two black wires are being fed from the same location from behind the center console. I looked behind the ignition and headlight switch and couldn't find where they would connect to.
Forcedair1
05-14-2023 03:28 PM
jagent
09-12-2015 01:40 AM
danpop
XJ40 ( XJ81 )
09-08-2015 03:23 PM
jaguarbill
09-05-2015 11:43 AM
philwarner
09-05-2015 10:05 AM
Quick Reply: Wiring Question
