Fuel Leak XJ6 Series 3
Old 02-25-2015, 11:40 AM
Jose's Avatar
Received 2,425 Likes on 1,826 Posts
you welcome.
what took you 30 secs ? the plastic check valve?
Old 02-25-2015, 01:50 PM
Jimmysea's Avatar
So:
Could just not manage to get the hoses completely clamped off, but using some of that goo you recommended, and replacing the clamps on all 3 connections to the tank switch unit did the trick apparently. Repressurized, ran the motor with both tanks, no leak after 30 minutes.
Woohoo.
Attached is a picture of the unit next to the fuel pump at the back of the spare well. It has a drain hose. Can you ID it?
Old 02-25-2015, 01:58 PM
Jose's Avatar
that looks like the electric antenna motor
Jimmysea (02-25-2015)
Old 02-25-2015, 05:50 PM
Jimmysea's Avatar
Originally Posted by Jose
you welcome.
Yes
Old 02-25-2015, 05:51 PM
Jimmysea's Avatar
Makes sense, thanks. The drain hose on it fooled me..
Old 02-25-2015, 07:20 PM
anjum's Avatar
That's there to let all the elctrikery mind control from aliens to drain away safely! Stick some silver foil over it just in case...
Jimmysea (02-26-2015)
Old 02-26-2015, 06:35 AM
Jose's Avatar
now you need to drive the car to see if the vapor buildup has dissapeared when you open the gas filler cap.
  #28
Old 02-26-2015, 09:43 AM
Jimmysea's Avatar
Indeed it has...
Thanks Jose.
Old 02-26-2015, 10:31 AM
Jose's Avatar
alright John!
now you need to edit the thread title and add "SOLVED" to it.
  #30
Old 03-03-2015, 09:01 AM
Jimmysea's Avatar
Default Oh Boy
I would put "Solved" but still smelling gasoline inside the car...
One day....
  #31
Old 03-03-2015, 12:21 PM
Jose's Avatar
Originally Posted by Jimmysea
I would put "Solved" but still smelling gasoline inside the car...One day....
ok, there are two vapor "tanks", one on each "C" pillar, and I bet that is where the smell is coming from;
getting to those is not easy, there are two ways to get to them and check the hose connections:
1) through the interior of the car; Each C pillar has a headliner cover which can be carefully pried off, and you can see if the smell is concentrated there,
2) through the trunk; That access entails removing the large drain pan located in the trunk under the rear parcel shelf, you can see the hoses on each corner of the drain pan. The good news is that if you remove this drain pan, you can clean the accumulated centuries of crud from it, paint it, and fix the vent flaps that create the "cowbell" noise when you close the doors.
The following 2 users liked this post by Jose:
JagLoverT (03-19-2015), yarpos (03-04-2015)
  #32
Old 03-04-2015, 01:14 AM
yarpos's Avatar
Received 2,086 Likes on 1,261 Posts
Ahhh, thats what that rattle is. It was on my list of annoying stuff , once I finish my list of keeping the car running stuff, thanks you have saved me some time.
Old 03-04-2015, 08:50 AM
Jose's Avatar
yes, there are 4 "free-hanging flaps" rivetted to the Drain Pan, you can see them through the hole "vents" located in the rear "cowl" of the trunk (see the yellow arrows in picture).
to get to them and fix the noise, you have to remove the black Drain Pan (see the red arrow in picture). It's a 2-day job.
the repair consists of going to Jo Ann's Fabrics and getting a sheet of thick black FELT fabric, (or any color you want, just don't use Pink, please), and gluing cut pieces of felt to the front of each flap with Contact Cement which you bought at HomeDepot.
originally, the factory glued pieces of Headliner fabric to these thin metal flaps, but the glue dries out and the pieces of fabric fall off, creating metal-to-metal contact and the famous "cowbell" noise/rattle.
**Note that there are two more of these flaps located behind the rear seat Back. Same repair, but to get to those you remove the upholstery panel / cover where all the electronics are in the trunk. ( Series 3 XJ )
yarpos (03-04-2015)
pnwrs2000
09-05-2015 10:16 AM
Jag-o-nomic
09-04-2015 03:07 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Fuel Leak XJ6 Series 3
