valve adjustment
Old 04-20-2014, 09:04 AM
gray cat's Avatar
Default valve adjustment
my 86 XJ6 has 138 ,000 miles on her . she runs ok ........although i think she could do better.
would this be a good time to adjust the valves ???
Old 04-20-2014, 11:10 AM
icsamerica's Avatar
Received 1,359 Likes on 790 Posts
Default consider this
At that mileage...I'd start with a compression test. AFAIK you need to adjust the valves if they are noisy.
Old 04-20-2014, 01:58 PM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
I am very surprised you've got to that mileage without a top-end overhaul, frankly. Good advice on compression test. Valve adjustment can be a bit of a PITA if you cannot get the right thickness shims. A neat trick is to turn them over, so the little dent the valve eventually makes in the shim is on the other side and the valve bears on a fresh surface. You will definitely need a micrometer if reusing shims, because the thickness letter code wears off.
Old 04-20-2014, 02:29 PM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
Well, it might be a good time to check the adjustment, at least. Checking the valve clearance is easy. *Adjusting* the valve clearance is a royal pain in the butt.
Agreed on the compression test.
Do both and decide from there.
Old 04-22-2014, 03:03 PM
gray cat's Avatar
thanks much guys !!! i will let you know what happens from here
Cheers KO
MrWhite
19
06-14-2022 07:49 PM
Marka
22
09-11-2016 12:09 AM
xjrjag
10-12-2015 03:16 PM
Nigels420G
Mark V - X 420G
09-27-2015 03:48 PM
BSM
09-25-2015 05:00 PM
Quick Reply: valve adjustment
