XJC revving high
XJC revving high
Hi Guys,
This is my first post in this forum having sold up in Thailand. I'm back in the UK and once again getting to know my 1976 Daimler XJC 4.2.
It was put away in a garage for quite a long time whilst I have been away and when I finally got home to take a look, the engine was found to rev very high on start up (1,600rpm)
From research, I see a number of threads complaining about the automatic choke with many installing a manual instead. I prefer to keep it original, and want to know is this a fixable or replacement item? Is this a job a 5/10 mechanic (me) could attend to?
With thanks in advance
Hi Richard,
Different people will have different opinions about the automatic choke (AED). I chose to leave it in place and managed to get it working as intended. I bought a revision kit and carefully installed it myself. Be careful that you don't damage anything. I had never done any work on carbs before. I then took it to a professional for tuning, which takes a bit of time as the car needs to be started cold a few times to get it right. Once properly tuned the AED should work fine.
Must be tough re-adjusting to life in the UK coming back from Thailand. Good luck!
Noud
Noud
I had this problem on my 69 XJ6.
It would idle up to 1500-1800rpm, then would at times be just above normal idle at 1200rpm.
The roadside mechanic took off the intake, sprayed some carby cleaner in the carby and left it sit for a few minutes then it was fine. probably not a permanent fix but if you tried that and it worked, it might just be time to clean the carby rather than fiddle with other stuff.
Received 2,399 Likes
