fuel pump wont start
Old 01-31-2012, 05:34 PM
calvindoesntknow's Avatar
Default fuel pump wont start
ive rebuilt my xjs from the ground up, totall engine rebuild new transmission (5 speed swap) and now that i am trying to hook the ECU up i cant get the fuel pump to turn on, the computer relaay turns on and there is power to the fuel pump relay i just cant get continuity on the fuel pump relay negative, any thoughts?
Old 01-31-2012, 06:26 PM
Mish_Mish's Avatar
Yes, tell us more about 5-speed swap please.
Old 02-01-2012, 02:31 AM
Received 10,309 Likes on 6,819 Posts
Thumbs up
Since you dont give a year, I will assume it is a HE engine, in an '80's car??.
IF SO.
The "main relay" switches the fuel pump realy ON, BUT, the earth circuit of that relay is ECU controlled. Look at the fuel pump relay socket. You will see an Orange wire, that is the earth wire. If you cut that wire, and earth the socket section, that will remove the ECU from earth control of that relay, including the timer circuit. This will have the fuel pump working whenever the ign is ON, and care will need to be taken if the wiring is left that way. NOT my recomendation, but quite suitable for diagnosis purposes.
If that fails to get power to the pump, then the relay might be fried inside, it does happen. If power is achieved, but still no pump operation, the pump has gone AWOL.
Old 02-01-2012, 06:24 AM
JameyXJ6's Avatar
LOL@Mish_mish
Old 02-06-2012, 08:04 PM
ill tell you guys all about the five speed swap, and post pics once i can diagnose that fuel pump problem and get it running. and im sorry its an 87 xjs
Sprayall
05-30-2021 08:13 AM
dsnyder586
04-04-2019 02:38 PM
Charlene n John
09-28-2015 06:01 AM
Charlene n John
09-06-2015 11:03 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: fuel pump wont start
